This is a follow up video explaining how the clutch type tap wrenches work. It shows the parts in detail and being assembled, a new style tap wrench and a free parts drawing in the description.
https://youtu.be/SYzP5GlbTBk?si=thL6Lf6L8Ws5B0dd
Hi Mook:
I do like to use your idea of using a grub screw instead of single point threading all those handles. I keep a supply of grub and other threaded rod around to avoid threading.
Thanks, Carl.
Hi Mook:
I'm also a dumpster diver and one Sunday I hit the dumpster at a nut and bolt house. They must have just done a major clean up since their dumpster was loaded with threaded rod cut offs and overstock bolts. Must have pick up #500 of hardware. Now I only but special sizes I need in bulk.
Carl.
Thanks Mook! We've added your Tap Wrench Clutch Mechanism to our Tapping and Threading category,
as well as to your builder page: Mook's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-tap-wrench-clutch-mechanism"> <img src="/uploads/276541/homemade-tap-wrench-clutch-mechanism.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-tap-wrench-clutch-mechanism">Tap Wrench Clutch Mechanism</a> <span> by <a href="https://www.homemadetools.net/builder/Mook">Mook</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/ratchet'>ratchet</a>, <a href='https://www.homemadetools.net/tag/tapping'>tapping</a>, <a href='https://www.homemadetools.net/tag/clutch'>clutch</a> </div> </div> </div> </div>
