Results 1 to 10 of 15
Thread: GAS STATION FAIL!
    Supporting Member machining 4 all's Avatar
    May 2020
    machining 4 all's Tools
    GAS STATION FAIL!
    Keep your workplace clean!
  2. The Following User Says Thank You to machining 4 all For This Useful Post:
    nova_robotics (Jan 12, 2021)
    jdurand's Tools
    Never had a problem before!
  4. The Following User Says Thank You to jdurand For This Useful Post:
    Supporting Member toeless joe's Avatar
    Oct 2019
    Denver,CO
    How do you nominate someone for a Darwin Award?
    Jun 2018
    Louisiana
    Incredible
    Supporting Member thevillageinn's Avatar
    Jul 2017
    thevillageinn's Tools
    Hopefully it’s diesel - but not likely. I surely wouldn’t have been sticking around to get the video.
    Oct 2016
    old kodger's Tools
    Ever cross anybody's mind that it could be water? Just because it LOOKS like a fuel hose does not make it so.
  9. #7
    May 2020
    Note that the hose is connected to the pump! Maybe it's fueling water-powered cars...
  10. #8
    Mar 2018
    Hoosiersmoker's Tools
    It's water. The way it behaves when it hits the ground would indicate that. Gasoline "soaks" into the surface and spreads. You would also see indications of the fumes / evaporation disturbing the image just above the surface of the concrete. Just because the hose goes to a metal stand some call a "gas pump" doesn't mean it picks up fuel from the tanks below. Not being able to see the plumbing, there's no telling what feeds the nozzle. Many have stated it can't be unless cars run on water. What about radiators? Those need water on occasion don't they? Maybe he had it installed specifically to do what the video shows him doing with it!!! Hmmm... I use a screwdriver as a chisel or pry bar sometimes and cheap calipers to scribe lines but a screwdriver isn't a chisel or pry bar and calipers aren't a scribe. Is it a fuel nozzle or just a nozzle? The answer is: It depends on what you use it for! Let's light a match and find out!
  11. #9
    May 2020
    It is not allowed in my country, by law, water points near fuel pumps. The factors are obvious: leakage, corrosion, maintenance, etc. This gas station would have its license revoked if it did this! Watering cans are used to fill the radiators, so the only way to prove it is gasoline is to actually light a match. Would you dare to fill the tank at this gas station?
  12. #10
    Even if it is water, having water come out of a fuel pump handle is a dumb idea; too easy for some dummy to pump water into his gas tank.
