Thread: Gasket Cutter Circle cutter with prints. Mill or 3Dprint
    jjr2001's Tools
    This is an easy one with both the ability to 3d print it or make it using
    standard machine shop methods.
    Aluminum works fine for this or use steel and brass for good looks.
    Depending on the position of the blade holder the max/min capacity can be changed
    from "largest to smallest"
    Cheers, JR
    Attached Thumbnails Attached Thumbnails Gasket Cutter Circle cutter with prints. Mill or 3Dprint-img_3491.jpg   Gasket Cutter Circle cutter with prints. Mill or 3Dprint-img_3492.jpg   Gasket Cutter Circle cutter with prints. Mill or 3Dprint-img_3493.jpg
    Attached Files Attached Files
    Back to the shop.
  2. The Following 5 Users Say Thank You to jjr2001 For This Useful Post:
    davesrepair (Mar 8, 2025), emu roo (Mar 8, 2025), philippacificnw (Mar 10, 2025), PJs (Mar 9, 2025), tatoga (Mar 10, 2025)
    Thanks jjr2001! We've added your Gasket Circle Cutter to our Miscellaneous category,
