hmm blue rino should be doing this with thier tanks.....Ive had somany of their tanks that leek. bad seals, bad valves. but they assure me they all get rebuilt every time they get refiled......no they get a quick paint if needed and a new plastic sleve over the tank if the old one is dead... you can not fix stupid. I have 6 good tanks that I have refilled, not exchanged. allways look at the one they give you for exchange, look at the seal for rot ,dry,hard,cracks.if it look ok then after installing it open the valve half way and let it sit for 30 min then do the sniff test...many have leekey seals on the shaft.you can also do the soapy water test witch should be done on all installations. do it with the valve closed.then part open then open. look for bubbles when rotating the knob at the shaft.and all over the valve assy too.
I do agree, you have to look them over good before you accept one. BUT I have discovered that you can swap old style or out of date tanks, for usable ones. I got 10 out dated tanks from a site I was cleaning up, exchanged them for good ones at Lowes. When empty I take the good tanks to be refilled. When you get them filled, you get 17 pounds of propane, Blue Rhino only puts 15 in them.
