AlexD (Jun 30, 2017), AmateurMachinist (Apr 6, 2019), bgerens (Jun 28, 2017), blkadder (Jul 5, 2017), byates (Dec 9, 2022), cmolinel (May 15, 2019), dietmar g (Jul 4, 2022), emu roo (Oct 30, 2025), EnginePaul (Jun 4, 2021), glenntref (May 28, 2018), high-side (May 16, 2019), Home-PC (Jun 2, 2021), john komo (Jun 3, 2021), Jon (Jan 23, 2024), kboy0076 (Nov 12, 2024), Komo (May 29, 2018), LMMasterMariner (Jun 29, 2017), Moby Duck (Jun 29, 2017), NortonDommi (Jun 28, 2017), oldcaptainrusty (May 25, 2018), olderdan (Jun 27, 2017), Paul Jones (Jun 29, 2017), rayh__ (Jun 29, 2022), rossbotics (Jun 26, 2017), Seedtick (Jun 27, 2017), Sleykin (Jan 12, 2026), sossol (Jul 4, 2024), stainless stål (Jun 27, 2017), thehomeengineer (Jan 21, 2018), Toolmaker51 (Jul 31, 2017), tuchie (Jan 3, 2025), vaiavela (Jul 17, 2017), warsztatOdZera (Apr 9, 2019), Workshopshed (May 26, 2018)
Comments are always welcome
Doug
Thanks mate!
As i said its just a prototype.. Just noticed that i should have bend a V- groove to the bottom plate.. It would work good guide when cutting bigger pipes. I got some other improvements on my mind too. Maybe i need to make that over engineered version too?![]()
Thanks Tuomas! We've added your Angle Grinder Modification to our Grinding category,
emu roo (Oct 30, 2025), Home-PC (Jun 2, 2021), Paul Jones (Jun 29, 2017), Seedtick (Jul 4, 2017)
Finished.
Some improvements. I'll update this section until its finally "done".
1. Another option for the handle.
2. Screw that locks the angle grinder to the stand so that it doesn't move sideways when tightening screw is loose. Good when using as a chop saw. It also secures straight cuts if tightening screw opens itself.
3. Quick tightening action with simple thump screw, made from M12 nut and piece of flat bar.
Down its loose. Up, its tightened.
4. Bigger guard for safer use.
5. add supports that guides angle grinder to the same line with the base, faster and easier assembly.
6. Optional support wheel, helps with wood carving and grinding.
Will be continued with the attachments for grinding and pipe cutting... Also im waiting my wood cutting blades,
Then this will work as a circular saw too.
Stay tuned!
Thank you. Im working on with the pipe cutting attachment atm. That was the actual reason with this. It should be finished soon. I'll be back then.
