Thanks Stefano. Food for thought from experience...When I get to a stuck point it is easy to get into a hurry up, try this try that mode and usually forget to document what I did and the Results. I relate it to trying to fight my way out of the inside of a balloon!![]()
Usually I find that letting it go for a day or two, something bubbles to the surface that either puts me on the right track or the actual solution. Allow some Ω time. ~¿@
The 1.5Mhz filter is a bit odd to me too, but it's mainly the configuration of the 2 filters in series. I do not consider it (1.5Mhz) an RF filter in this circuit.
As for the coil builds...Start with the calcs and work a little either side of what is needed. The 10-40 turns is a big swing...especially changing diameters too. Document each!!
Had another thought about the coil and the proximal capacitance effects. Maybe you are experiencing issues because of that??
As they say...Rome wasn't built in a day...but it did get built...as well as the Sistine chapel. ~¿@ You'll get it built too! Thanks for sharing with us. ~PJ![]()
