Results 1 to 10 of 198
Thread: Good advices for a newbie (threading tools lathe)
    Nov 2015
    Italy
    rendoman's Tools
    bad news today
    I tried to measure both first stage gain and second one. I switched between pentode and triode connection, I changed from resistor load for pentode to output transformer.
    summing:
    - first stage voltage amp (little triode of pcl82 tube) imput 820mV for maximum voltage gain of 50v
ID:	12151 Click image for larger version.
ID:	12153 Click image for larger version.
    - output stage triode connection , imput from generator (I will measure this a 3rd probe even from first stage) max 360mV for 114v output
ID:	12155 Click image for larger version.
    - output stage pentode connection , 244mV for 136v output
ID:	12158Click image for larger version.
    Clean limits, after this threshold curve become bad.
    I tried also measure with output transformer and speaker - 9,1 ohm resistor ( I didin't have 8ohm at home ), output voltage is really low, under half watt in "clean" curve, I settled tek scope to ch1-2 rms voltage. Anode voltage is 310v, I'm thinking about something happened to catode resistor. I need to focus and think what happened inside circuit.
    I put x10 probe (x10 key on tek display) on pentode point, 1x on low voltage signal
    I think I'll check every component, cap, resistor, socket. I will be ignorant, but the p-p power should be max voltage output (undistorted) / load resistor in ohm, maybe something near 0,2w, Who has eaten the other watts?
    I will find an answer!
    funny picture with ear protection
    Here a small noisy video, at the end you can see the sine changing
    Little edit, I missed one part of formula, power is 1,5w in triode, not 0,2. power is V2/r or R*I2 or V*i
  2. The Following 2 Users Say Thank You to rendoman For This Useful Post:
    Paul Jones (Jul 5, 2016), PJs (Jul 4, 2016)
