https://youtu.be/_EA6g5uHpm0
Thanks fergiomaria! We've added your Trolley to our Miscellaneous category,
as well as to your builder page: fergiomaria's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-trolley-3"> <img src="/uploads/259691/homemade-trolley-3.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-trolley-3">Trolley</a> <span> by <a href="https://www.homemadetools.net/builder/fergiomaria">fergiomaria</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/pulley'>pulley</a>, <a href='https://www.homemadetools.net/tag/bearing'>bearing</a> </div> </div> </div> </div>
Appreciate the rapid yet step x step and clear format of video, the auxiliary spotlighting, and completely acceptable background music [performed by actual musicians, it seems!]
The idea of fabricating a heavy linear guide opens all kinds of projects......... I suppose sliding doors found on barns are world wide, common hardware here isn't adequate for a serious door panel. Security, insulation, weather seal, ease of moving several hundred pounds estimated weight.
This could solve a wall opening I cannot use, based on hardware used then, 1897, hardly different than available today.
