Assembly and disassembly in any groove position!
https://youtu.be/wWBhrUwnno8
Thanks machining 4 all! We've added your Swivel T-Nut to our Machining category,
as well as to your builder page: machining 4 all's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-swivel-t-nut"> <img src="/uploads/248037/homemade-swivel-t-nut.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-swivel-t-nut">Swivel T-Nut</a> <span> by <a href="https://www.homemadetools.net/builder/machining+4+all">machining 4 all</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/milling'>milling</a>, <a href='https://www.homemadetools.net/tag/table'>table</a> </div> </div> </div> </div>
Machining the nut dimensions 0.2 mm smaller than the slot dimensions! :cool:
Attachment 38869
Ok, interesting but why? What is the advantage? Besides being able to insert and take the nut out of the t-slot without having to run to the end?
Ralph
Thanks for your interest Ralphxyz! Mount and dismount dividing head, tailstock, vise, etc. it's easier with clean slots, do you agree? Slots full of chips make assembly and disassembly difficult. Cleaning slots with mounted devices is not so pleasant. Even with a collector or compressed air, small fragments remain hidden. Think about disassembling T nuts on milling machines with very long work tables, it would be a real marathon ...
Attachment 38876 Attachment 38877 Attachment 38874
Yes agreed, do you/could you start with a piece of round stock?
Ralph
If I understood your question correctly, you could start making this nut according to the drawing below. Thanks for your interest again!
Attachment 38879
Thanks, putting it on my list of things to do, of course I can never find that list when I actually have some time to do things.
Ralph
Time is a sign of preference! I also have a list of things I can never complete! :lol:
This is a great idea. Adding it to my list. I still would recommend using regular T nuts for really heavy loads.
Cheers
Willy
Thanks for the comment and interest willyb!
The use I put them to is changeover, where clamping that worked for one set of operations isn't going to for next. You can drop them in wherever/ whenever needed. Including after starting out with too few regular tee-nuts, but you're dialed in.
Toolmaker51, thank you for your interest and comments!
