I used to have one of those HF bead rollers what I did was to mount it on a 4 legged pipe stand made out of 3" sch 40 pipe then cut 2 pieces of 1/2" plate similar in shape as the main frame "C" then sandwiched the main frame between them and welded them in place . Then I used a 32" diameter wheel to replace the crank simply because I had one laying around. Later I replaced the adjusting bolt and nut with a sacrificed "C" clamp Mine worked great for me
