Results 1 to 9 of 9
Thread: Heat treat oven
    Supporting Member Eaglewood's Avatar
    Mar 2016
    Eaglewood's Tools
    Heat treat oven
    Heat treat oven-b9f01276-c7c1-4cf0-86ef-3319e4224da8.jpg I decided that I needed a more controlled method of heat treating than a torch so this is what I came up with. I didn’t want to “glue “ the bricks so I used gasket rope in a dado to insure a seal and made the frame so that it clamped the bricks. The unit has one inch of insulation around the bricks and seems to work as the outside temperature at 2000 degrees is less than 200 degrees with no detectable leakage around the door.Heat treat oven-4ebabce6-16bc-4bb2-9901-82ae471c9187.jpeg
    Initially I had problems with the Kanthal wire oxidizing and the double twisting of the wire to the supply didn’t work either so I welded the wire to 1/4 bolts to feed to the outside and that cured both problems.Heat treat oven-5fcf0a1b-ff8e-40c5-ac24-ec12b9411a3c.jpegHeat treat oven-16eac62c-65b0-49a5-998f-4a4c7a93206f.jpeg
    I elected to use a long thermocouple with a collet arrangement to allow me to position the probe as close as possible to the part being treated.Heat treat oven-34365f4c-8c26-4c63-ba1c-bb375157d3ff.jpg
    The controller is a typical PID with SSR and I sized the wire(16 gage) to supply about 2800 watts which seems about right for the size of the chamber (8 1/2x9x13)Heat treat oven-45a0ec40-4446-4bfa-8f9d-0309d1c0b6ce.jpeg
    I also kind of attempted to calibrate the oven by melting salt,lead,aluminum and copper and it seems to be accurate. I have more pics if anyone has questions and comments and critiques are welcome. I would appreciate suggestions to make the oven better. I am used to rework😃
  2. The Following 15 Users Say Thank You to Eaglewood For This Useful Post:
    albertq (Jul 14, 2022), carloski (Jul 11, 2022), clydeman (Jul 10, 2022), cogentia (Nov 20, 2020), Crusty (Nov 14, 2020), Duke_of_URL (Nov 16, 2020), Jon (Nov 14, 2020), Little Rabbit (Aug 16, 2022), mwmkravchenko (Nov 16, 2020), neilbourjaily (Nov 16, 2020), nova_robotics (Nov 22, 2020), rayh__ (Nov 16, 2020), Scotsman Hosie (Nov 30, 2020), Tonyg (Nov 23, 2020), Toolmaker51 (Apr 7, 2022)
    Thanks Eaglewood! We've added your Heat Treatment Oven to our Heating and Cooling category,
    as well as to your builder page: Eaglewood's Homemade Tools. Your receipt:
    Dec 2016
    Ralphxyz's Tools
    Thanks, something like this is on my List.
    On your calibration testing were you able to melt copper? I need to look up "Kanthal wire". How much wire did you use?
    Are you running 220 volts?
    I like it, thanks for posting.
    Ralph
    Mar 2016
    Eaglewood's Tools
    I used 16awg Kanthal wire from Wireoptim. I was shooting for approximately 5 ohms and ended up with about 5.2 at 16 feet with a 4 inch tail on both ends. This cyfers out at about 2760 watts at 120 v. I also wound the wire on a 3/8 mandrel and with the tension I used ended up with about a .41 dia. and made the grooves in the bricks 3/8. The wire pressed into the grooves nicely with no other need for retention. When heating it is drawing close to 23 amps which puts it in the 2760 watt range.
    I used thin pieces of cooper not knowing the actual composition but it started to go liguidius at around 1950 or so. Not a real scientific method but gave me a feeling that the tc/pid were in the neighborhood.
    Oct 2013
    Cumming, GA
    What insulating brick did you use and where did you get it?
    Thanks,
    Ed Taylor
    There are many sources for "vaping" (the cigarette substitute) supplies on the net. They stock Kanthal A1 wire. It seems that it is for a small heater in the device.
  8. #7
    Mar 2016
    Eaglewood's Tools
    I used insulating fire brick, soft and easy to work and a higher insulating factor. I live in northern Vermont so it wasn’t available around here so I had to order it online. A ceramic supply company should have it. I got mine from AARDVARK CLAY AND SUPPLIES. I used 24 bricks @3.85 each. They were VERY well packed and arrived in perfect condition.
  9. #8
    Dec 2016
    Ralphxyz's Tools
    I do not like the the 23 amps on a 110v line, could I wire up with 220 volts.
    Would you just wire each leg to a phase?
    Ralph
  10. #9
    Mar 2016
    Eaglewood's Tools
    I chose to go 120 because it was more convenient for me to connect to a existing circuit but would have used 220 otherwise. The pid and ssr I bought from Auber Instruments will handle either voltage. I used 10 wag wire and suitable connectors to connect to my main box which is very close to the oven.
    Download plans for forging and casting tools.
