Results 1 to 10 of 13
Thread: Heat Treating Aluminium [Easy DIY method]
    Supporting Member Bongodrummer's Avatar
    Dec 2013
    Wales
    Bongodrummer's Tools
    I wondered how difficult it would be to do a T5 heat treatment on the aluminium parts I have been making recently? If it was possible, would it be worth doing?🧐🔧
    Turns out that it was easy, requiring no special equipment, and, yes(!) very much worth doing! Here's the video, where I explore the process.
    Bongodrummer
    Subscribe to my Youtube Channel
    FloweringElbow.org Blog
    Flowering Elbow on Facebook
  2. The Following 28 Users Say Thank You to Bongodrummer For This Useful Post:
    123pugsy (Mar 7, 2019), 12L14 (Jul 31, 2019), Corm (Mar 7, 2019), DIYSwede (Jun 2, 2019), Dorn (Mar 7, 2019), earl (Mar 10, 2019), hemmjo (May 11, 2025), Inner (Mar 10, 2019), johncg (Jul 17, 2021), lassab999 (Feb 22, 2023), Little Rabbit (Feb 21, 2023), MeJasonT (Apr 30, 2019), mikeatl (Feb 14, 2026), mwmkravchenko (Mar 6, 2019), natie123 (Mar 10, 2019), nova_robotics (Feb 21, 2023), oldpastit (Mar 7, 2019), Paul Jones (Apr 21, 2019), PJs (Aug 12, 2024), Ralphxyz (Jul 18, 2021), Resident114 (Dec 9, 2022), saintrain (Apr 7, 2019), Scotsman Hosie (Mar 7, 2019), Seedtick (Mar 6, 2019), Sleykin (Mar 10, 2019), tooly (Feb 13, 2026), uv8452 (Dec 8, 2022), WmRMeyers (Dec 9, 2022)
    Thanks bongodrummer! We've added your Aluminum Heat Treatment Method to our Forging and Casting category,
    as well as to your builder page: bongodrummer's Homemade Tools. Your receipt:
    You might find this of interest in regard to hardness testing of your samples.
    http://www.homemadetools.net/forum/s...832#post102624
  5. The Following 2 Users Say Thank You to tonyfoale For This Useful Post:
    DIYSwede (Jun 2, 2019), MeJasonT (Apr 30, 2019)
    Jan 2017
    Nice but minimal introduction to the topic.
    You do not mention the specific alloy(s) or family of alloys you're using.
    Makes a HUGE difference!
    You also mention casting the alloy. 60xx alloys are wrought, typically rolled or extruded.
    Smelting and casting these makes them something different.
    T5 is an artificial aging heat treatment to some common aluminum alloys. 6063 or 6061 typically.
    Increases hardness and strength.
    Water quench from above critical temperature actually anneals the same alloys.
    Water quench from elevated temp simply stops the heat treatment process at that time.
  7. The Following 2 Users Say Thank You to jimirwin For This Useful Post:
    MeJasonT (Apr 30, 2019), Paul Jones (Apr 21, 2019)
    Oct 2012
    I have a movie about metal and the properties. In it when aluminium was first made they questioned the same thing. I'll look through my library to see if I can find it.
    Aluminium can be hardened but not with the normal heating. I get back when I find it, I might have hours of movies to look through so it might be a while.
    Nelson
    Oct 2012
    Bongodrummer
    I was able to find the video I spoke about. It is almost an hour but around 38 minutes will get around to a surprising aluminium hardening that will blow you away.
    The video can be had at:
    https://www.bing.com/videos/search?q...6&&FORM=VRDGAR
    If that link does not work try to google: I use the BING search engine that might make a difference.
    Documentary - How It Works 1of3 Metal
    Good luck and enjoy the movie.
    Nelson
  10. The Following 4 Users Say Thank You to ncollar For This Useful Post:
    Corm (Dec 9, 2022), DIYSwede (Jun 2, 2019), greenie (Dec 15, 2022), odd one (Jul 17, 2021)
  11. #7
    olderdan's Tools
    Quote Originally Posted by ncollar View Post
    Bongodrummer
    Documentary - How It Works 1of3 MetalGood luck and enjoy the movie.
    Nelson
    Absolutely fascinating video Nelson, thanks for posting.
  12. #8
    Dec 2013
    Wales
    Thanks Nelson! I actually remember watching this on TV years ago! It's a good one. I especially liked the creep resistant, single crystal castings at the Roles Royce factory. Though I wish there was a little more detail about why the little spiral at the bottom only let one crystal through...
    Bongodrummer
  13. #9
    Oct 2012
    Bongodrummer
    It is the way we think sometimes that just leads to another question.
    Good Luck with your venture.
    Nelson
  14. #10
    Jan 2017
    Aluminum heat treating
    Quote Originally Posted by jimirwin View Post
    Each alloy family has its own processes. Some are quite unique. I worked in an aluminum alloy extrusion and door & window manufacturing company as an intern during my senior year. One of my jobs was to study and characterize heat treatment of 6061/6063 alloys using the metallurgy labs at Texas A&M.
    I also worked in the physics dept machine shop during my junior year. (Been a metal cutter/mangler since age 10...73 now!)
    heat treating, as we have come to call it, is really artificial aging. i.e. the same physical properties will develop over time even under normal temperatures. Elevated heat just speeds the process.
    Other alloys have their own processes.
    7075 high strength alloys have a troubling propensity to change dimensions over time. One must design in such considerations.
    Just one of many examples.
  15. The Following 2 Users Say Thank You to jimirwin For This Useful Post:
    DIYSwede (Jun 2, 2019), Jon (May 29, 2019)
