I think the connectors are quite important if you want an accurate measurement. Thermocouples work by two different metals meeting at a point (and being welded together) and generating a tiny voltage. If you connect them to some other material then you effectively introduce another thermocouple junction where the thermocouple meets the other wire and hence add another tiny voltage, giving an offset reading. There's a bit of a discussion on this starting on the last comment on this page of the thread on the woodhaven2 forum.
The green† K-type thermocouple connectors have the pins (and sockets) made of a material that doesn't introduce any offset (as long as you also have thermocouple cable the other side of the plug/socket going to the controller). The plugs and sockets aren't especially expensive - you can get some decent quality ones for a few pounds in the UK at least.
† I've said green as that's the international standard colour, but I think a different colour (yellow I think) is used in America because, well, America!![]()
