Results 1 to 5 of 5
Thread: Heavy binding post mk2
    Nov 2015
    Italy
    rendoman's Tools
    Hi all
    I just finished a set of heavy binding post, in brass.
    The design is focused on ease of use, they can also handle lot of current. I drilled 6mm hole for cables.
    I'm satisfied, the ability to hold the cable is strong, M8 threading provides lot of force, the diameter of knob allows to tighten strongly with little effort.
    I decided to build them for an amplifier, the old commercial binding post had the thread broken, despite not having made heavy use. To ensure the connector to the frame I cut a M10 thread, strong enough for heavy load.
    As usual, tons of pictures
    Stefano
    PS: I was wrong to post, It should be it in the finished parts section
    Heavy binding post mk2-dsc03994_1600x1200.jpg Heavy binding post mk2-dsc03996_1600x1200.jpg Heavy binding post mk2-dsc03997_1600x1200.jpg
ID:	23327 Heavy binding post mk2-dsc03864_1600x1200.jpg Heavy binding post mk2-dsc03865_1600x1200.jpg
    Heavy binding post mk2-dsc03867_1600x1200.jpg Heavy binding post mk2-dsc03868_1600x1200.jpg Heavy binding post mk2-dsc03873_1600x1200.jpg
    Heavy binding post mk2-dsc03881_1600x1200.jpg Heavy binding post mk2-dsc03887_1600x1200.jpg Heavy binding post mk2-dsc03985_1600x1200.jpg
    Heavy binding post mk2-dsc03988_1600x1200.jpg Heavy binding post mk2-dsc03992_1600x1200.jpg
  2. The Following 4 Users Say Thank You to rendoman For This Useful Post:
    Jon (Apr 17, 2018), Paul Jones (Apr 18, 2018), PJs (Apr 18, 2018), Seedtick (Apr 18, 2018)
    Thanks rendoman! We've added your Heavy Duty Binding Posts to our Electrical category,
    as well as to your builder page: rendoman's Homemade Tools. Your receipt:
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Now That's what I would call Heavy Duty...Size 1-2 wire and carry 100+Amps. How will you insulate them from the chassis, Delrin or ceramic?
    Well done Stephano!
    PJ
    Mark Twain
  5. The Following User Says Thank You to PJs For This Useful Post:
    rendoman (Apr 19, 2018)
    Nov 2015
    Italy
    rendoman's Tools
    Thank you PJs!
    I'm a bit undecided at the time, I have to install this set on a Lm3886 amp, not so much current used to the output. I'm building a compact frame, since the old one I built 15 years ago has some trouble, my skills and equipment were very limited and I made bad decision above all on anchoring system.
    The new frame is my usual steel frame welded, with aluminum panels, I will use Iroko wood for sides, I'm thinking about using this good wood even as insulator, do you think it could be a right choice? I have this wood in safe place, inside house for at least 25 years
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Quote Originally Posted by rendoman View Post
    Thank you PJs!
    Beautiful wood. My Djembe from Burkina Faso is made from it I believe, for its resonant properties. Personally I would put some kind of insulator on it with thin walls and for sake of ease, use white/black Delrin (Acetyl). Perhaps 2 top hat types per, inside and out...easy enough to make. Since you are likely only pushing <100W it would probably be fine through the wood. It's old enough and dry enough I would think after 25yrs of acclimatizing, but there may be a certain resistance across it, which you could measure with an Ohm Meter. Safer than sorry is my motto.
    ~PJ
    Mark Twain
