Page 5 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 41 to 50 of 71
Thread: Heavy lift ring crane - video
  1. #41
    That crane was already at or slightly above its rated capacity and the least amount of additional drag caused by the dozer blade or loader bucket which ever the case may be as all it took to drive the point home. I imagine there were several brown shorts after that , hope the operator survived.
  2. #42
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    And the operator says; And What exactly am I lifting? Know thy limitations!
    Mark Twain
  3. #43
    He probably would have been fine had he raised the dozer until it was above the bank before swinging or if he could have boomed up more before awinging after he had the dozer above the edge.
    will52100 (Sep 15, 2018)
  5. #44
    Jan 2016
    Moby Duck's Tools
    At around 10 seconds two people appear running on the left of the crane cab. I think the second one in brown is the crane driver making a hasty exit.
    As soon as the boom hits the concrete edge and breaks, there is a huge amount of black dust that appears to fall off it. Rust perhaps?
  6. #45
    Of the two exiting, one in blue was near the edge of the excavation, maybe a spotter. He was on the run sooner, 'joined' by the one in brown, who may have been the operator. He probably had different color pants just minutes before...He looks to be stepping down such as he would exiting cab. Those two could run a few steps and be in the clear.
    Another WTF is two rappelling to pit floor. Perspective makes closer man very close to that crane block flying around wildly. Even 50' away, he had to see it; that would be a longer 'oh s_ _ _' moment than the crane tipping.
    Frank S is right, operator should have continued lifting before swing. There are several anchor rods protruding from pit face, one really looks to get jammed in the front left track of bulldozer, I'll bet that is what really started things downhill. Few of the other workers seem to know anything was going on. The 6 or so that do, might have started scattering when outboard track of crane started to lift, or heard something give way.
    Last edited by Toolmaker51; Sep 16, 2018 at 08:50 AM. Reason: Even Shakespeare had re-writes...
  7. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    Frank S (Sep 16, 2018), PJs (Sep 16, 2018)
  8. #46
    Two crane GIFs from typhoon Mangkhut, which made landfall in The Philippines yesterday.
    First, a close call:
    And a fail:
    What's the correct procedure for handling a crane in a major storm? Disassemble? Secure? Was the crane in the first GIF intentionally left to rotate for the storm, so that it spins rather than collapses?
  9. The Following 3 Users Say Thank You to Jon For This Useful Post:
    PJs (Sep 16, 2018), Seedtick (Sep 22, 2018), Toolmaker51 (Sep 16, 2018)
  10. #47
    I'm certain this is an apartment kitchen. Can you imagine morning tea in one hand, other hand filming this?
    At least they didn't drop the phone, nor appear to have ducked.
    I'd be, after the third go-round; Mornin' dear, spot of tea?, come take a look at this storm!
  11. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    PJs (Sep 16, 2018)
  12. #48
    Supporting Member Drew1966's Avatar
    Oct 2016
    <source src="https://diqn32j8nouaz.cloudfront.net/crane_almost_hits_building.mp4" type="video/mp4">
    </video>
    And a fail:
    <source src="https://diqn32j8nouaz.cloudfront.net/crane_falls_in_typhoon_mangkhut.mp4" type="video/mp4">
    </video>
    My family lived in Hong Kong during the late 80’s, and the new China Bank building was being constructed directly in front of our apartment (albeit a good thousand yards away).
    As I am sure you are aware, Hong Kong gets its share of typhoons.
    When the work was stopped, say on a Sunday, the four tower cranes had large “flags” hung off them and the slew(?) unclutched. This allowed them to turn with the wind. Also, the crane towers were well tied into the building structure itself, I assume to give added rigidity.
  13. #49
    hemmjo's Tools
    The operator also had the boom of the crane improperly aligned with the tracks for that lift. On that machine, the tracks appear to be longer that they are wide. He should have had the boom about 30-45 deg to the right when he began the lift, then swung to 30-45 deg left to set it down. It appears he is already about 30-45 left when he began the lift, the tried to swing toward 90 deg (the weakest position on the machine) when the disaster happened.
  14. The Following User Says Thank You to hemmjo For This Useful Post:
    Moby Duck (Sep 17, 2018)
  15. #50
    After the typhoon:
  16. The Following 3 Users Say Thank You to Jon For This Useful Post:
    PJs (Sep 17, 2018), Seedtick (Sep 22, 2018), Toolmaker51 (Sep 17, 2018)
