Results 1 to 9 of 9
Thread: Help me choose a chainsaw
  1. #2
    Choosing a chainsaw can be one of the more difficult things a person will do in their life time. Some will say even more difficult than choosing a life partner.
    My first chainsaw was a McCulloch mini mac about 50 years ago. I cut a lot of wood with it but don't remember overall how well I liked it over later brands that I have owned. Back then we had Ethel gasoline and had to mix our own fuel.
    I currently own a Sthil TS510 Demolition saw that is probably at least 30 years old and a Sthil 028 about 25 years old Both are heavy but they were considered industrial machines.
    My newest chainsaw is a Sthil MS170 about 3 years old fairly light weight or probably considered almost a medium weight.
    All are still working real well I also only use pre mixed chainsaw fuel mostly because the gasoline we can get these days has already started to go bad before we buy it at the pump. even the premium grades higher octane does not contain long term stabilizers Never run the E85 pump gas as ethanol has a bad effect on the fuel systems of small engines. Pre mix fuel is expensive around $32.00 a gallon and may not be worth the extra cost in the long run If you can get really good quality premium gas without ethanol and are careful when mixing it may be OK I don't use it because I sometimes need to store my fuel for a few months and the 93 Octane pre mix fuel seems to serve that purpose
    As far as Husqvarna goes A lot of professionals use them as well as Echo & Poulan I think a lot depends on personal choice and the availability of service or repair.
    If you have a reputable small engine repair center near you, you might ask them if they will honsetly tell you which brand has the most frequent repair issues.
    Here again it is going to depend a lot on how much your husband will be using his saw and for what. If he is just going to do the occasional trimming and limbing of smaller limbs up to 4" he may be better off with a CORDED electric. if he is going to do daily or weekly trimming then a battery powered may be a good choice.
    If he is going to be cutting several cords of fire wood each fall then a 16 to 18" gas powered the 12 to 14" gas powered saws are mostly used for trimming and limbing
    Care and maintenance as well as storage are a huge factor in how well a chainsaw of any make or brand preforms.Beyond that I can't not recommend which way you should go.
  2. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    olderdan (Sep 6, 2018), Paul Jones (Sep 11, 2018)
