Results 1 to 9 of 9
Thread: Hex wrench size chart
  1. #3
    Quote Originally Posted by pfredX1 View Post
    I did not know about the SAE numbers. I just made a holder with every size hex wrench I have in it, in ascending order. SAE and metric. So if none of those fit, then I don't have the Allen key.
    I think you've missed the point. The idea is to avoid the need to try successive wrenches for a fit. Assuming you know the specification of the SHCS or set screw, just look at the chart and select the wrench it shows.
    For example, if you're using a 6-32 cap screw, the chart says you need the 7/64" hex wrench. A 4-40 set screw will require the 0.050" wrench.
  2. The Following User Says Thank You to mklotz For This Useful Post:
    Paul Jones (Aug 25, 2017)
