Results 1 to 8 of 8
Thread: HF Welder cart mod 3
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    HF Welder cart mod 3 Electrical box receptacle quick release plug.
    HF Welder cart mod  3-new-zealand-2018-016.jpgHF Welder cart mod  3-new-zealand-2018-017.jpg
  2. #2
    I like having the ability of storing the power cord off of the cart. I'm just not fond of having a double male cord which according to your pictures this might be the way you went with it. here is a picture of a couple of inlet receptacles which allow for the use of a standard design male female cord.
    A Nema L14-30 More than enough amp cap for the little welder
  3. The Following User Says Thank You to Frank S For This Useful Post:
    metric_taper (Sep 21, 2019)
    Jul 2014
    Hi Frank, Well it all started when i had this generator that had a female 220 volt outlet then I bought a 20 ft extension cord, then I wanted to adapt it to the welder.
    So I put a big red light on the power box and never turned it on before I plugged it in . and so it is now.
    Quote Originally Posted by Captainleeward View Post
    I know the feeling I had a generator set up that way for a while at a place I lived. But one day I needed the cord for something else and changed 1 end then instead of needing to change it back every time I wanted to use the generator as auxiliary power I bought one of the recessed male connectors to install at the house problem solved and the risk of someone else not knowing the double male cord. I left the female receptacle on the house as well giving me double use out of my cord.
    DIYSwede (Oct 29, 2019)
    Dec 2017
    Suicide Cord.
    This is a direct violation of National Electrical Code Section 406.6 (A) and (B). Commonly called "suicide cords". Remember you will be held personally libel if it causes a fire or someone receives a shock. I would deem this not worth the risk. Other methods to avoid this have been shown by Frank S. Worth the cost.
  8. The Following 2 Users Say Thank You to BLLG For This Useful Post:
    DIYSwede (Oct 29, 2019), metric_taper (Sep 21, 2019)
    Thanks Captainleeward! We've added your Welder Cart Electrical Outlet to our Electrical category,
  10. #7
    Jul 2014
    OK I will change the system for the better.
  11. #8
    Feb 2015
    Manitoba Man's Tools
    Quote Originally Posted by BLLG View Post
    I hear you, that bright short cut might be your last idea.
