Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: High Speed Spindle (Router) Mount for a CNC Mill
    Supporting Member Wmrra13's Avatar
    Jan 2015
    Wmrra13's Tools
    Scorch,
    That's a very illustrative photo - Thanks!
    Gate, sprue, riser, registering system on the sandbox, scorched wood...
    Hmmm... Maybe that's how you got your name?
    -Tyler
  2. #12
    Hell inside that tin wont freeze over. Nice furnace theme, scorch.
  3. #13
    owc
    owc is offline
    May 2015
    I see that you made it to mill wood, but how will it perform milling aluminum?
  4. #14
    Supporting Member scorch's Avatar
    Apr 2015
    Oakdale, MN
    scorch's Tools
    Quote Originally Posted by owc View Post
    I think the mount will do fine with aluminum. It is really stout. I am a little worried about where the aluminum chips are going to go with the router running. There is a lot of airflow coming from the bottom of the router. I have a feeling there is going to be aluminum chips all over the workshop and potentially inside the router.
  5. #15
    May 2015
    baskarz's Tools
    Yep aluminium chips go EVERYWHERE, learnt that the fun way.
    And they did eventually get sucked into the router and went *splat*.
    luckily it was only a brief short and i just took it apart and cleaned it all up.
    I ended up hotgluing some material to the air inlet on the router and works perfectly.
  6. #16
    owc
    owc is offline
    May 2015
    Tnx to Scorch & Baskarz. I will WATCH the chips.
