1 Attachment(s)
High Speed spindle tool for the lathe
Hi,
I already showed different approaches to mount a rotary tool on the lathe, a Dremel mount or a Drill mount or here and the smaller chuck version here.
In that quest, I think I have found the ultimate solution, which fixes all the drawbacks of the different solutions above.
1st quality, there is no or very small run-out, second it features an ER11 chuck which allows for a wide range of bit diameters (ok, up to 7mm).
In addition it is quite powerfull (400W) and can spin from 0 to 12000 rpm, with good torque even at low speed.
This spindle is actually a CNC spindle sold on the well known Chinese platforms. I purchased mine on eBay, and I must say that I am so far very happy for the value and quality.
The kit contains the spindle, air cooled, the power supply, 48V / 480W (quite usefull by itself) , a PWM controller board with a potentiometer to regulate the speed, and a clamp designed to hold the body of the spindle with 4 screws.
http://www.labellenote.fr/file/homem...pindlel_01.jpg
My plan is to install that spindle in the QCTP of my metal lathe.
I had to slightly modify the aluminum clamp, milling flat the bottom of the sole, and then I screwed this steel dovetailed plate, in order to fit the QCTP socket.
http://www.labellenote.fr/file/homem...pindlel_02.jpg
Here is how looks the spindle tool ready for mounting in the QCTP.
http://www.labellenote.fr/file/homem...pindlel_03.jpg
Then I had to pack all the components and mainly isolate the power supply and control board.
I had the idea of making a box that would have a double purpose : enclose all the component AND tidying up all the parts for transport and storage.
http://www.labellenote.fr/file/homem...pindlel_04.jpg
Here is the box finished and closed
http://www.labellenote.fr/file/homem...pindlel_05.jpg
And on the left part, you can see the parts and cords in it.
http://www.labellenote.fr/file/homem...pindlel_06.jpg
I can attach the box to the lathe with two simple wire hooks
http://www.labellenote.fr/file/homem...pindlel_07.jpg
Ready to use the tool
http://www.labellenote.fr/file/homem...pindlel_08.jpg
The spindle tool mounted in axial position
http://www.labellenote.fr/file/homem...pindlel_09.jpg
The dovetail allows for height adjustment. I think I will improve it with a screw mechanism for fine adjustment.
http://www.labellenote.fr/file/homem...pindlel_10.jpg
The spindle tool mounted in transverse position
http://www.labellenote.fr/file/homem...pindlel_11.jpg
