Results 1 to 4 of 4
Thread: Hobbing Worm Wheel - Need Help
    Jan 2016
    Dubrovnik - Croatia
    LMMasterMariner's Tools
    Need to know diameter of worm wheel for the following numbers of teeth: 30, 32, 36, 40
    for worm dia 24 mm x metric trapezoidal thread TR3
    Even have plenty round bars of phosphorus bronze in various diameters wouldn't like
    to use hit and miss approach.
    Many thanks in advance / Best regards
    LMMasterMariner
  2. The Following User Says Thank You to LMMasterMariner For This Useful Post:
    Seedtick (Sep 6, 2017)
    olderdan's Tools
    Quote Originally Posted by LMMasterMariner View Post
    LMMasterMariner
    Found this in Engineers Handbook which may help.
    Not sure of your method of cutting these but if free hobbing you need to gash the teeth first.
    I think I would try a test on plastic or alloy to prove, good luck.
  4. The Following 2 Users Say Thank You to olderdan For This Useful Post:
    LMMasterMariner (Sep 6, 2017), Seedtick (Sep 6, 2017)
    Jan 2016
    Dubrovnik - Croatia
    Thanks Olderdan.
    I also found some info in 'Handbook of Machining and Metalworking Calculations' and 'Machinery's Handbook 29th Edition (2012)' which I have in my pdf collection.
    Yes, my intention is to use free hobbing method.
    Already made hob from s.s. 304 24 mm dia hex rod. At the same time on the same rod made worm.
    Here is picture of that and also picture (found on the web) of what hob should be when I finish it.
    Best regards
    LMMasterMariner
    Attached Thumbnails Attached Thumbnails Hobbing Worm Wheel - Need Help-1.jpg   Hobbing Worm Wheel - Need Help-2.jpg
  6. The Following User Says Thank You to LMMasterMariner For This Useful Post:
    Nov 2015
    South Australia
    O/D=(n+2)Śmod
  8. The Following User Says Thank You to viking For This Useful Post:
    LMMasterMariner (Oct 26, 2017)
