Page 4 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 31 to 40 of 93
Thread: Hobo nickels: intricate carvings in coins - GIF and photos
  1. #31
    1:54 Shaun Hughes video:
    Also some vise ideas here: Lindsay Engraving Vises, holders and fixtures
  2. The Following 6 Users Say Thank You to Jon For This Useful Post:
    high-side (Dec 23, 2018), PJs (Dec 22, 2018), rendoman (Dec 22, 2018), Scotsman Hosie (May 22, 2019), Seedtick (Dec 22, 2018), thevillageinn (Dec 23, 2018)
  3. #32
    Supporting Member rendoman's Avatar
    Nov 2015
    Italy
    rendoman's Tools
    Hi all!
    Someone has some good info about how this type of engraver is made?
    Thanks!
  4. #33
    I think that is some reverse alien technology!
  5. #34
    Nov 2015
    Italy
    rendoman's Tools
    At first sight it seems a piston that acts like an hammer. Looking the spring I would think that it works in depression. I remember this tool has a power unit with air flow control. It would be nice to try one!
  6. #35
    Quote Originally Posted by rendoman View Post
    I think your appraisal is correct. A miniaturized pneumatic hammer. I think a piston could be induced to reciprocate like a two cycle engine - where one port is covered alternately. Light spring operated poppets might work too, opened by piston impact, returning to a starting position triggering that poppet.
  7. #36
    Nov 2015
    Italy
    rendoman's Tools
    Just out of curiosity, I tried drawing a couple of sketch.
    The left tool should should work with positive pressure, in few words a compression chamber and a piston, like you said a 2 stroke engine. According to this design I think the mass of piston, type of segments and force (plus centering) of the spring should be the key of the tool. At first sight I suppose it would be the simplest way, choosing the right size and pressure should be the hard part. I suppose the limit of this setting is the reloading speed, the spring should be the limit itself.
    The right drawing should be better and perform faster, if well tuned. A good comparison should be like a desmodromic valve system of Ducati against a normal spring distribution, it should run faster. I think here the hard job is the timing of the valve double air, send and return.
    Looking at the commercial product I found in the net, I think the first one should be the most used. I'm thinking about a way to built a simple driver unit to try
    What do you think about?
    Hobo nickels: intricate carvings in coins - GIF and photos-dsc04978_1600x1200.jpg
    PS: I found this link with some interesting pictures, I don't know if it's possible to post, or it's against forum rules. If it's not ok, please delete http://bbs.homeshopmachinist.net/thr...eumatic-graver
  8. #37
    Yes, of course you can post links to other forums; we know many of them, and they certainly link to us! We've logged 400+ different forums that link to homemadetools.net.
    You can also browse tools by site, here: Homemade tools by site . For example, here are 509 homemade tools from homeshopmachinist.net: Homemade Tools from bbs.homeshopmachinist.net.
  9. The Following 2 Users Say Thank You to Jon For This Useful Post:
    PJs (Dec 26, 2018), Scotsman Hosie (May 22, 2019)
  10. #38
    The Chicago Pneumatic CP 9361 Industrial Scribe and Engraving Pen works well as an engraver just change out the pointed scribe for a shaped tool
    They are pricey though And I mean really pricey. at around $300.00 with the regulator
  11. #39
    Rendo;
    after googling the desmodromic actuation there are some positives. Doing it miniature may or may not be a challenge.
    So that causes wonder if a motor and valve train could be remote, running the handpiece off a hose? Handpiece could have it's own piston, delivering inertia to the graver. A light spring might induce rearward travel with each reduced pressure wave. Probably not feasible, but I've never considered how to run such a device.
    re google this turned up. A new frame of reference to what I call "real engineers".
    After World War II, when future Ducati engineer Fabio Taglioni wrote his original engineering-school paper on desmodromic valve drive, there was good reason to seek such a system: Valve springs broke at random as an era of rising rpm opened. In the 1950s, NSU pushed to 12,000 rpm,...
    https://www.cycleworld.com/2014/04/2...o-desmodromics
  12. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    PJs (Dec 26, 2018)
  13. #40
    Audrey Hepburn on 1925 nickel with copper inlay. By myguitarismymistress.
  14. The Following 6 Users Say Thank You to Jon For This Useful Post:
    Andyt (Jan 25, 2019), jackhoying (Jan 24, 2019), PJs (Jan 24, 2019), rlm98253 (Jan 24, 2019), Scotsman Hosie (May 22, 2019), Seedtick (Jan 24, 2019)
