Results 1 to 8 of 8
Thread: Home built leaf vacuum
    nicky1's Avatar
    Feb 2015
    Lisbon,Ohio
    nicky1's Tools
    I have needed one of these for years and when someone threw the engine/fan in the scrap metal hopper at the Cat dealership where I worked I couldn't resist the temptation to grab it. The engine had no compression and it turned out to be a stuck valve. After removing the head and cleaning everything it runs great. The body is almost all aluminum and the under carriage is steel with a widened MTD tractor front axle. The blower chute sides are made from excavator plexiglass windows, which is 1/4 in. or so thick and is tough stuff. It works great and will make the fall cleanup a lot easier.
    Home built leaf vacuum-img_2358.jpgHome built leaf vacuum-img_2359.jpgHome built leaf vacuum-img_2360.jpg
  2. #2
    Very nice indeed, but if I were you I'd create a thread about this in the homemade tools forum that way you will recieve credit for a nicely made homemade tool even if it is a re-creation
  3. #3
    nicky1's Avatar
    Feb 2015
    Lisbon,Ohio
    nicky1's Tools
    I couldn't get it to post there ???
  4. #4
    Moving it over now...
  5. #5
    Thanks nicky1! We've added your Leaf Vacuum to our Farm and Garden category,
    as well as to your builder page: nicky1's Homemade Tools. Your receipt:
  6. #6
    Supporting Member Wmrra13's Avatar
    Jan 2015
    Wmrra13's Tools
    Quote Originally Posted by nicky1 View Post
ID:	12348Click image for larger version.
ID:	12349Click image for larger version.
    Nice job! I had a similar unit (not as nice as yours) that came with the house when we bought it. I used it a LOT until it pretty much vibrated itself to pieces. To fix it I found an engine/fan unit on CL and scabbed it all together - works great but still not as nice a job as you did!
  7. The Following User Says Thank You to Wmrra13 For This Useful Post:
    nicky1 (Nov 16, 2018)
  8. #7
    nicky1's Avatar
    Feb 2015
    Lisbon,Ohio
    nicky1's Tools
    Thank you very much!! I tried to put it in that category and it just wouldn't cooperate.
  9. #8
    Aug 2019
    I am looking to build a leaf vacuum. But I am having trouble finding the blower and engine set up. Can you point me the direction to find one online?
