Results 1 to 9 of 9
Thread: Homemade cnc router vice
    May 2015
    baskarz's Tools
    Hey all, here's my little vice i made on my cnc for my cnc
    Wanted a vice i could bolt to the cnc table and be able to machine parts in it, also as a multipurpose vice with interchangeable jaws.
    So this is what i came up with.
    Made it from scraps of 6061 in various thickness, 20mm hdpe for the leadnut and a leftover of tr102d trapezoidal leadscrew.
    Only mistake was the holes for the jaws, 5mm off, all good tho.
    One change i will make is a longer slide piece to give the jaw more stability once tightening.
    Homemade cnc router vice-20150503_162545.jpgHomemade cnc router vice-20150503_162556.jpg
    Homemade cnc router vice-20150503_162617.jpgHomemade cnc router vice-20150521_182530.jpg
    Worked a treat and I made a pair of locating jaws to hold a 25mm cube and as a test made a pseudo turners cube from the 25mm cube of ally. Quite happy how it turned out, much better than i expected, even gave it a quick squirt with the sandblaster for a cool finish
    Homemade cnc router vice-20150517_151002.jpgHomemade cnc router vice-20150517_154620.jpg
  2. The Following 10 Users Say Thank You to baskarz For This Useful Post:
    Altair (May 24, 2015), bgerens (Oct 22, 2017), blkadder (Oct 22, 2017), emu roo (Apr 14, 2025), Jon (May 21, 2015), JRock (Mar 27, 2018), kbalch (May 21, 2015), mwmkravchenko (Jun 12, 2020), panosam (Jun 3, 2015), Paul Jones (May 21, 2015)
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Baskarz,
    Nice work and vise design. You have great photos for the details. Question: Did you thread the movable vise jaw all the way through or just threaded the two nylon (?) parts on either side?
    Paul
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks baskarz! I've added your CNC Router Vise to our Vises category, as well as to your builder page: baskarz's Homemade Tools. Your receipt:
    May 2015
    baskarz's Tools
    cheers!
    I'll post some deconstructed pictures later on to show how it all comes together.
    The hdpe nut is an insert to the jaw and is the only part threaded.
    Envious of that vice you made. Well done!
    May 2015
    baskarz's Tools
    As promised, here are a couple more photos showing how it goes together.
    I couldn't be bothered completely disassembling the vice but you get the idea
    The nyloc nut on the end of the leadscrew wasn't quite the same thread as the screw and so i just forced it on as i don't intend on removing it any time soon, sure is tight!
    Homemade cnc router vice-20150524_125425.jpgHomemade cnc router vice-20150524_125443.jpg
    Homemade cnc router vice-20150524_125603.jpgHomemade cnc router vice-20150524_125620.jpg
  8. #7
    Impressive work. Thanks for sharing baskarz.
    Al
  9. #8
    Supporting Member pfredX1's Avatar
    Sep 2016
    Delaware
    pfredX1's Tools
    I just use a drill press vise on my CNC when I want to use a vise. Not the best because the movable jaws on those always lift, but so far good enough for what I do.
    https://i.imgur.com/97JwhQF.jpg
  10. #9
    JimP in Oregon's Avatar
    Dec 2017
    Springfield, OT
    really nice job! thanks for sharing it.
    Download plans for cnc routers.
