Results 1 to 5 of 5
Thread: HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"
    Feb 2018
    San Diego, Cal.
    pkuphaldt's Tools
    This is my "ENGINE" LATHE / MILLING "HEAD" project.
    This project is a continuation of my "HOMEMADE METAL WORKING LATHE" and based on the Pat Delany "MULTI MACHINE" concept.
    Also see my "HOMEMADE 4 JAW CHUCK" project.
    This design is similar to Smithy Lathe/Mill machines.
    The Chevy 6 cyl. head is mounted to the front end of a slant 6 Mopar engine block
    standing vertically.
    Between the Mopar 6 cyl. block and the 6 cyl. Chevy head are two
    pieces of 6 " channel iron welded together. pics 8, 9, 14
    1/4" plate is welded to attach the lower channel iron to the front end of the
    vertical block using 13 factory made threaded holes. pics. 8, 9, 18
    The upper channel iron is drilled and tapped in 6 places to match
    existing factory head bolt hles. Stops are welded to channel iron by the
    exhaust ports. Clamps are bolted to the channel iron on the spark plug
    side of the head. pics. 8, 14
    The head can be located in two different positions and also swung out of
    the way when not in use. Always support the Milling "Head" when changing position
    or have at least 1 head bolt installed. pics 1, 8, 9, 18
    5 1/2" channel iron is bolted to the front end of the head
    where the thermostat housing normally bolts to the head using 3 existing
    threaded holes. Gussets are drilled to match existing taped holes in the head and welded
    to the 5 1/2" channel. pics. 3, 11, 18
    I made the drill arbor using parts from two Chinese drill presses. The
    shaft is from a motorcycle front strut. Sealed ball bearings are used
    top and bottom of the shaft. The telescoping drive shaft is made from 3/4" square tubing
    over 1" x .100 wall square tubing. A Mopar crankshaft pulley drives the
    1" square tubing. pics. 2, 3, 5
    A 6207 sealed ball bearing is used to locate the drive pulley. pics 6, 7
    A 1725 rpm motor drives the arbor using step pulleys on the jackshaft and
    motor. pics. 15, 16
    A cross slide made from a Chevy V8 head is on the horizontal engine
    block. This is used for both lathe and mill functions. pics. 8, 12, 13
    I am not going to put in a lot of specifics and measurements since most
    likely your project will become different because of different parts being used.
    Any project you build is at your own risk and liaibility. It's safety
    and operation is your responsibility. I relinquish all
    responsibility/liability in any project you build.
    Good luck and have fun!
    1HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"-dsc01374.jpg 2 HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"-dsc01367.jpg 3 HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"-dsc01369.jpg HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"-dsc01370.jpg4 5HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"-dsc01365.jpg 6HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"-dsc01366.jpg HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"-dsc01356.jpg7 8HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"-dsc01357.jpg 9HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"-dsc01358.jpg HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"-dsc01359.jpg10 11HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"-dsc01360.jpg 12HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"-dsc01361.jpg HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"-dsc01372.jpg13 14HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"-dsc01362.jpg 15HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"-dsc01363.jpg
    Attached Thumbnails Attached Thumbnails HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"-dsc01368.jpg   HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"-dsc01355.jpg   HOMEMADE "ENGINE" LATHE AND MILLING "HEAD"-dsc01364.jpg
  2. The Following 12 Users Say Thank You to pkuphaldt For This Useful Post:
    12L14 (Jul 31, 2019), Altair (May 26, 2019), baja (May 28, 2019), clydeman (Mar 24, 2025), emu roo (Jul 19, 2024), EnginePaul (Jun 2, 2019), Jon (May 26, 2019), JTC (Jun 2, 2019), Philip Davies (Dec 10, 2024), rlm98253 (May 27, 2019), Seedtick (May 27, 2019), Tonyg (Jun 3, 2019)
    Thanks pkuphaldt! We've added your Engine Lathe Milling Head to our Lathe Accessories category,
    as well as to your builder page: pkuphaldt's Homemade Tools. Your receipt:
  4. The Following User Says Thank You to Altair For This Useful Post:
    emu roo (Aug 20, 2025)
    skibo's Tools
    All I can say is WOW, what an undertaking!
  6. The Following User Says Thank You to skibo For This Useful Post:
    Aug 2016
    wizard69's Tools
    Nice work! By the way excellent pictures, they answer many questions that might come up and are very well done.
  8. The Following User Says Thank You to wizard69 For This Useful Post:
    Dec 2017
    Cape Coral, FL
    old_toolmaker's Tools
    pkuphaldt,
    That is quite the machine made from what appear to be old cast iron engine parts. It is unique and most likely solid. It is inspiring to say the least.
    Great invention and thanks for sharing with us!
    Download plans for lathes.
    Dick
    Links to some of my plans:
  10. The Following User Says Thank You to old_toolmaker For This Useful Post:
