Originally Posted by
Frank S
Great job I might have only one suggestion
I have used those adjustable pillow block bearing several times in the past. I found that in time no matter how Tight I thought I had them they would move just enough to cause a miss match My solution was to drill and tap a small piece of metal then weld one on each side to the adjustment then use a grub screw to hold the housing in place. It is a lot of work having to use two grubs on each bearing since you have 8 of them but it may pay off in the long run.
Again great job
