ANGLE GRINDER STAND
You can watch how to make an easy accessory for your angle grinder. Using the right disc you can easily cut every kind of materials like wood , metal and stone. You can cut for 35 cm length and less than 3 cm thick. You can adjust the angle you want to cut from 0 to 90 deg.
MATERIALS
1. Tube 2Χ2 cm 1,5 mm 4X20 cm. Holes 10 mm , κέντραπό 1 cm and 3 cm far from the end
2. Tube 3Χ3 cm 2-2.5 mm 1X80 cm and 2x16 cm
3. Bearings Dex. 30 mm - Din. 10 mm 8 mm thick 8 pieces.
4. Angle profile 3Χ3 cm 38.5 cm .
5. Angle profile 3X3 cm 10,5 cm 2 pieces .
6. screw 10 mm περίπου 1,20 m.
7. nuts Μ 10 about 40 pieces and screws 10 χιλ. 4Χ5 cm.
8. For the grinder 3 cm X 2-2,5 mm , length 35 cm .
9. To connect the grinder screws 8 mm with nuts M8 .
10. Ring 25 cm to tight the grinder.
11. Wooden base 2,5 – 3 cm 40 Χ 60 cm.
YOU CAN WATCH THE CONSTRUCTION AND THE USE HERE:
