Results 1 to 5 of 5
Thread: Homemade Softbox Light using LED Ceiling Lights
    Supporting Member Lahis's Avatar
    Nov 2018
    Australia
    Lahis's Tools
    Lightbulb Homemade Softbox Light using LED Ceiling Lights
    How to make Softbox Light using LED Ceiling Lights 230V
  2. The Following 8 Users Say Thank You to Lahis For This Useful Post:
    Frank S (Dec 3, 2018), Jon (Dec 4, 2018), mwmkravchenko (Dec 6, 2018), PJs (Dec 5, 2018), rgsparber (Dec 4, 2018), rlm98253 (Dec 4, 2018), rossbotics (Dec 6, 2018), stuffucanmake (Dec 16, 2018)
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Great idea! I plan to make one.
    Thanks,
    Rick
    Rick
  4. The Following User Says Thank You to rgsparber For This Useful Post:
    Lahis (Dec 28, 2018)
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Great post and build for cheap and cheerful costs. 6500k temp is a good starting point but have found through experience that around 5500-6000k is a more natural daylight white. What was the filter material you used? Looked like frosted acetate. Please Let us know how they hold up to the heat. Minor Tip: if you put them up higher, pointing them more straight down you will reduce the double shadows.
    Thanks for sharing a good build with us!
    PJ
    Mark Twain
  6. The Following User Says Thank You to PJs For This Useful Post:
    Thanks Lahis! We've added your Softbox Lights to our Photography and Videography category,
    as well as to your builder page: Lahis's Homemade Tools. Your receipt:
    PJ
    The filter material is from thermal laminating sheets, there should be no/insignificant heat from the LED Lights.
    If there was a lot of heat, then the filter material would go clear.
