Homemade tools made with Harbor Freight tools
Here's a rundown on some Harbor Freight tools we have listed in the encyclopedia. To get this list, I simply searched the database for "Harbor Freight" and "HF".
Some misc Harbor Freight tips are at the bottom. Additional tools? Tips? Advice? Post in this thread. :)
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="/upgraded-hf-bead-roller"><img src="/uploads/13298/upgraded-hf-bead-roller.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/upgraded-hf-bead-roller">Upgraded HF Bead Roller</a>
<span> by <a href="/builder/ak%27s-r-us">ak's-r-us</a></span>
</div>
<div class="tags">tags: <a href="/tag/bead-roller">bead roller</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/square-tube-bending-die-for-hf-pipe-bender"><img src="/uploads/30/square-tube-bending-die-for-hf-pipe-bender.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/square-tube-bending-die-for-hf-pipe-bender">Square Tube Bending Die for HF Pipe Bender</a>
<span> by <a href="/builder/cboy">cboy</a></span>
</div>
<div class="tags">tags: <a href="/tag/pipe-bender">pipe bender</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/powered-hf-bead-roller"><img src="/uploads/306/powered-hf-bead-roller.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/powered-hf-bead-roller">Powered HF Bead Roller</a>
<span> by <a href="/builder/Dammit">Dammit</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/modified-hf-bead-roller"><img src="/uploads/288/modified-hf-bead-roller.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/modified-hf-bead-roller">Modified HF Bead Roller</a>
<span> by <a href="/builder/mosimpson">mosimpson</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/harbor-freight-bead-roller-modifications"><img src="/uploads/252/harbor-freight-bead-roller-modifications.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/harbor-freight-bead-roller-modifications">Harbor Freight Bead Roller Modifications</a>
<span> by <a href="/builder/Jim+Stabe">Jim Stabe</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/hf-bead-roller-stand"><img src="/uploads/2791/hf-bead-roller-stand.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/hf-bead-roller-stand">HF Bead Roller Stand</a>
<span> by <a href="/builder/NealinCA">NealinCA</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/tig-electrode-sharpener"><img src="/uploads/15328/tig-electrode-sharpener.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/tig-electrode-sharpener">TIG Electrode Sharpener</a>
<span> by <a href="/builder/courtjester">courtjester</a></span>
</div>
<div class="tags">tags: <a href="/tag/grinding">grinding</a>, <a href="/tag/welder">welder</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/inexpensive-router-lift"><img src="/uploads/6613/inexpensive-router-lift.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/inexpensive-router-lift">Inexpensive Router Lift</a>
<span> by <a href="/builder/Vestus">Vestus</a></span>
</div>
<div class="tags">tags: <a href="/tag/lifting">lifting</a>, <a href="/tag/router">router</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/hf-mill-z-axis-upgrade"><img src="/uploads/8681/hf-mill-z-axis-upgrade.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/hf-mill-z-axis-upgrade">HF Mill Z-Axis Upgrade</a>
<span> by <a href="/builder/FLSTEAM">FLSTEAM</a></span>
</div>
<div class="tags">tags: <a href="/tag/cnc">CNC</a>, <a href="/tag/mill">mill</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/hf-motor-reversing-switch-wiring"><img src="/uploads/3911/hf-motor-reversing-switch-wiring.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/hf-motor-reversing-switch-wiring">HF Motor Reversing Switch Wiring</a>
<span> by <a href="/builder/wlw_19958">wlw_19958</a></span>
</div>
<div class="tags">tags: <a href="/tag/electrical">electrical</a>, <a href="/tag/motor">motor</a>, <a href="/tag/rewiring">rewiring</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/jib-crane-for-mill"><img src="/uploads/813/jib-crane-for-mill.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/jib-crane-for-mill">Jib Crane for Mill</a>
<span> by <a href="/builder/platypus20">platypus20</a></span>
</div>
<div class="tags">tags: <a href="/tag/jib-crane">jib crane</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/lifting-table"><img src="/uploads/5597/lifting-table.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/lifting-table">Lifting Table</a>
<span> by <a href="/builder/seal+killer">seal killer</a></span>
</div>
<div class="tags">tags: <a href="/tag/table">table</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/portable-bandsaw-vertical-bracket"><img src="/uploads/15960/portable-bandsaw-vertical-bracket.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/portable-bandsaw-vertical-bracket">Portable Bandsaw Vertical Bracket</a>
<span> by <a href="/builder/Machine_Punk">Machine_Punk</a></span>
</div>
<div class="tags">tags: <a href="/tag/bandsaw">bandsaw</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/english-wheel-5"><img src="/uploads/16008/english-wheel-5.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/english-wheel-5">English Wheel</a>
<span> by <a href="/builder/Howard+Connelly+Design">Howard Connelly Design</a></span>
</div>
<div class="tags">tags: <a href="/tag/light">light</a>, <a href="/tag/english-wheel">English wheel</a>, <a href="/tag/dolly-stand">dolly stand</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/vertical-bender-stand"><img src="/uploads/27960/vertical-bender-stand.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/vertical-bender-stand">Vertical Bender Stand</a>
<span> by <a href="/builder/Hiapo">Hiapo</a></span>
</div>
<div class="tags">tags: <a href="/tag/tube-bender">tube bender</a>, <a href="/tag/hydraulic">hydraulic</a>, <a href="/tag/ram">ram</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/extended-ratchet-handle"><img src="/uploads/43844/extended-ratchet-handle.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/extended-ratchet-handle">Extended Ratchet Handle</a>
<span> by <a href="/builder/nissan_crawler">nissan_crawler</a></span>
</div>
<div class="tags">tags: <a href="/tag/ratchet">ratchet</a>, <a href="/tag/hand-tools">hand tools</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/pinion-gear-puller-3"><img src="/uploads/44360/pinion-gear-puller-3.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/pinion-gear-puller-3">Pinion Gear Puller</a>
<span> by <a href="/builder/Witha+C">Witha C</a></span>
</div>
<div class="tags">tags: <a href="/tag/puller">puller</a>, <a href="/tag/motorcycle">motorcycle</a>, <a href="/tag/crankshaft">crankshaft</a>, <a href="/tag/pinion">pinion</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/drain-fitting"><img src="/uploads/49560/drain-fitting.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/drain-fitting">Drain Fitting</a>
<span> by <a href="/builder/Camfx">Camfx</a></span>
</div>
<div class="tags">tags: <a href="/tag/drain">drain</a>, <a href="/tag/fitting">fitting</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/stepped-fingers-for-sheetmetal-brake"><img src="/uploads/52444/stepped-fingers-for-sheetmetal-brake.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/stepped-fingers-for-sheetmetal-brake">Stepped Fingers for Sheetmetal Brake</a>
<span> by <a href="/builder/astroracer_2">astroracer</a></span>
</div>
<div class="tags">tags: <a href="/tag/sheetmetal">sheetmetal</a>, <a href="/tag/brake">brake</a>, <a href="/tag/flange">flange</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/tube-bender-12"><img src="/uploads/53488/tube-bender-12.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/tube-bender-12">Tube Bender</a>
<span> by <a href="/builder/rigger77">rigger77</a></span>
</div>
<div class="tags">tags: <a href="/tag/tube-bender">tube bender</a>, <a href="/tag/welding">welding</a>, <a href="/tag/pneumatic">pneumatic</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/nut-starter-2"><img src="/uploads/55352/nut-starter-2.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/nut-starter-2">Nut Starter</a>
<span> by <a href="/builder/James+Waldby">James Waldby</a></span>
</div>
<div class="tags">tags: <a href="/tag/lathe">lathe</a>, <a href="/tag/clamp">clamp</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/oval-tray-jig"><img src="/uploads/55692/oval-tray-jig.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/oval-tray-jig">Oval Tray Jig</a>
<span> by <a href="/builder/shipwright">shipwright</a></span>
</div>
<div class="tags">tags: <a href="/tag/jig">jig</a>, <a href="/tag/router">router</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/universal-pulley-holder"><img src="/uploads/65732/universal-pulley-holder.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/universal-pulley-holder">Universal Pulley Holder</a>
<span> by <a href="/builder/blknblu">blknblu</a></span>
</div>
<div class="tags">tags: <a href="/tag/pulley">pulley</a>, <a href="/tag/crankshaft">crankshaft</a>, <a href="/tag/holder">holder</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/brake-drum-puller-2"><img src="/uploads/70196/brake-drum-puller-2.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/brake-drum-puller-2">Brake Drum Puller</a>
<span> by <a href="/builder/cell">cell</a></span>
</div>
<div class="tags">tags: <a href="/tag/puller">puller</a>, <a href="/tag/brake-drums">brake drums</a>, <a href="/tag/welding">welding</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/drive-adaptor-for-pipe-threader"><img src="/uploads/71060/drive-adaptor-for-pipe-threader.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/drive-adaptor-for-pipe-threader">Drive Adaptor for Pipe Threader</a>
</div>
<div class="tags">tags: <a href="/tag/pipe">pipe</a>, <a href="/tag/welding">welding</a>, <a href="/tag/threading">threading</a>, <a href="/tag/adaptor">adaptor</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/minibike-lift"><img src="/uploads/73168/minibike-lift.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/minibike-lift">Minibike Lift</a>
<span> by <a href="/builder/byron+ness">byron ness</a></span>
</div>
<div class="tags">tags: <a href="/tag/motorcycle">motorcycle</a>, <a href="/tag/lifting">lifting</a>, <a href="/tag/workstand">workstand</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/solar-powered-auxiliary-power-system"><img src="/uploads/78716/solar-powered-auxiliary-power-system.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/solar-powered-auxiliary-power-system">Solar-Powered Auxiliary Power System</a>
<span> by <a href="/builder/Feedthelibertytree">Feedthelibertytree</a></span>
</div>
<div class="tags">tags: <a href="/tag/toolbox">toolbox</a>, <a href="/tag/fan">fan</a>, <a href="/tag/battery">battery</a>, <a href="/tag/power-supply">power supply</a>, <a href="/tag/electronics">electronics</a>, <a href="/tag/controller">controller</a>, <a href="/tag/inverter">inverter</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/rim-roller-3"><img src="/uploads/79248/rim-roller-3.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/rim-roller-3">Rim Roller</a>
</div>
<div class="tags">tags: <a href="/tag/workbench">workbench</a>, <a href="/tag/roller">roller</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/angle-grinder-table-saw"><img src="/uploads/82504/angle-grinder-table-saw.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/angle-grinder-table-saw">Angle Grinder Table Saw</a>
<span> by <a href="/builder/Rick+Sparber">Rick Sparber</a></span>
</div>
<div class="tags">tags: <a href="/tag/angle-grinder">angle grinder</a>, <a href="/tag/table-saw">table saw</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/english-wheel-13"><img src="/uploads/100056/english-wheel-13.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/english-wheel-13">English Wheel</a>
<span> by <a href="/builder/captainleeward">Captainleeward</a></span>
</div>
<div class="tags">tags: <a href="/tag/welding">welding</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/multifunction-divider-and-compass"><img src="/uploads/101400/multifunction-divider-and-compass.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/multifunction-divider-and-compass">Multifunction Divider and Compass</a>
<span> by <a href="/builder/CedarSlayer">CedarSlayer</a></span>
</div>
<div class="tags">tags: <a href="/tag/grinding">grinding</a>, <a href="/tag/divider">divider</a>, <a href="/tag/compass">compass</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/reverse-tumbler-modification"><img src="/uploads/102853/reverse-tumbler-modification.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/reverse-tumbler-modification">Reverse Tumbler Modification</a>
</div>
<div class="tags">tags: <a href="/tag/lathe">lathe</a>, <a href="/tag/modification">modification</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/round-tubing-layout-jig"><img src="/uploads/120228/round-tubing-layout-jig.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/round-tubing-layout-jig">Round Tubing Layout Jig</a>
</div>
<div class="tags">tags: <a href="/tag/tubing">tubing</a>, <a href="/tag/jig">jig</a>, <a href="/tag/layout">layout</a>, <a href="/tag/casters">caster(s)</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/mini-lathe-cross-slide-dro"><img src="/uploads/236524/homemade-mini-lathe-cross-slide-dro.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/mini-lathe-cross-slide-dro">Mini Lathe Cross Slide DRO</a>
<span> by <a href="/builder/DaveInPA">DaveInPA</a></span>
</div>
<div class="tags">tags: <a href="/tag/lathe">lathe</a>, <a href="/tag/dro">DRO</a>, <a href="/tag/cross-slide">cross slide</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/t-square-fence-and-table-extension"><img src="/uploads/122415/t-square-fence-and-table-extension.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/t-square-fence-and-table-extension">T-Square Fence and Table Extension</a>
<span> by <a href="/builder/mr95gst">mr95gst</a></span>
</div>
<div class="tags">tags: <a href="/tag/square">square</a>, <a href="/tag/table-saw">table saw</a>, <a href="/tag/fence">fence</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/modified-harbor-freight-bead-roller"><img src="/uploads/279/modified-harbor-freight-bead-roller.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/modified-harbor-freight-bead-roller">Modified Harbor Freight Bead Roller</a>
<span> by <a href="/builder/themodernartist">themodernartist</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
</div>
</div>
<div class="title">
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/modifications-to-a-harbor-freight-english-wheel"><img src="/uploads/1500/modifications-to-a-harbor-freight-english-wheel.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/modifications-to-a-harbor-freight-english-wheel">Modifications to a Harbor Freight English Wheel</a>
<span> by <a href="/builder/James+P.+Riser">James P. Riser</a></span>
</div>
<div class="tags">tags: <a href="/tag/english-wheel">English wheel</a></div>
</div>
</div>
<div class="bimg">
<div>
</div>
</div>
<div class="title">
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/transmission-adaptor-for-cherry-picker"><img src="/uploads/831/transmission-adaptor-for-cherry-picker.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/transmission-adaptor-for-cherry-picker">Transmission Adaptor for Cherry Picker</a>
<span> by <a href="/builder/convx4">convx4</a></span>
</div>
<div class="tags">tags: <a href="/tag/transmission">transmission</a>, <a href="/tag/floor-jack">floor jack</a>, <a href="/tag/crane">crane</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/power-added-ring-roller"><img src="/uploads/873/power-added-ring-roller.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/power-added-ring-roller">Power-Added Ring Roller</a>
<span> by <a href="/builder/badshifter">badshifter</a></span>
</div>
<div class="tags">tags: <a href="/tag/ring-roller">ring roller</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/cherry-picker-shop-press"><img src="/uploads/912/cherry-picker-shop-press.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/cherry-picker-shop-press">Cherry Picker Shop Press</a>
<span> by <a href="/builder/mixedupamx">mixedupamx</a></span>
</div>
<div class="tags">tags: <a href="/tag/press">press</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/bead-roller-with-hand-wheel"><img src="/uploads/939/bead-roller-with-hand-wheel.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/bead-roller-with-hand-wheel">Bead Roller with Hand Wheel</a>
<span> by <a href="/builder/Glenn_2">Glenn</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/adjustable-body-dolly"><img src="/uploads/966/adjustable-body-dolly.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/adjustable-body-dolly">Adjustable Body Dolly</a>
<span> by <a href="/builder/4t64rd">4t64rd</a></span>
</div>
<div class="tags">tags: <a href="/tag/autobody">autobody</a>, <a href="/tag/dolly">dolly</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/powered-bead-roller"><img src="/uploads/1008/powered-bead-roller.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/powered-bead-roller">Powered Bead Roller</a>
<span> by <a href="/builder/fbama73">fbama73</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/freestanding-visqueen-paint-booth"><img src="/uploads/1041/freestanding-visqueen-paint-booth.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/freestanding-visqueen-paint-booth">Freestanding Visqueen Paint Booth</a>
<span> by <a href="/builder/Christopher_2">Christopher</a></span>
</div>
<div class="tags">tags: <a href="/tag/painting">painting</a>, <a href="/tag/paint-booth">paint booth</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/hydraulic-tubing-bender"><img src="/uploads/702/hydraulic-tubing-bender.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/hydraulic-tubing-bender">Hydraulic Tubing Bender</a>
<span> by <a href="/builder/Twisted+Minis_2">Twisted Minis</a></span>
</div>
<div class="tags">tags: <a href="/tag/tube-bender">tube bender</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/accurized-craftsman-drill-press"><img src="/uploads/636/accurized-craftsman-drill-press.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/accurized-craftsman-drill-press">Accurized Craftsman Drill Press</a>
</div>
<div class="tags">tags: <a href="/tag/drill-press">drill press</a></div>
</div>
</div>
<div class="bimg">
<div>
</div>
</div>
<div class="title">
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/shop-crane"><img src="/uploads/294/shop-crane.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/shop-crane">Shop Crane</a>
</div>
<div class="tags">tags: <a href="/tag/crane">crane</a></div>
</div>
</div>
<div class="bimg">
<div>
</div>
</div>
<div class="title">
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/self-lifting-rotisserie"><img src="/uploads/1065/self-lifting-rotisserie.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/self-lifting-rotisserie">Self-Lifting Rotisserie</a>
</div>
<div class="tags">tags: <a href="/tag/rotisserie">rotisserie</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/bolt-cutter-rivet-crusher"><img src="/uploads/2713/bolt-cutter-rivet-crusher.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/bolt-cutter-rivet-crusher">Bolt Cutter Rivet Crusher</a>
<span> by <a href="/builder/CatCow">CatCow</a></span>
</div>
<div class="tags">tags: <a href="/tag/rivet">rivet</a>, <a href="/tag/hand-tools">hand tools</a>, <a href="/tag/gunsmithing">gunsmithing</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/deburring-tumbler"><img src="/uploads/3459/deburring-tumbler.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/deburring-tumbler">Deburring Tumbler</a>
<span> by <a href="/builder/Mark_2">Mark</a></span>
</div>
<div class="tags">tags: <a href="/tag/deburring">deburring</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/belt-grinderdeburrer"><img src="/uploads/3354/belt-grinderdeburrer.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/belt-grinderdeburrer">Belt Grinder/Deburrer</a>
<span> by <a href="/builder/lbhsbz">lbhsbz</a></span>
</div>
<div class="tags">tags: <a href="/tag/belt-grinder">belt grinder</a>, <a href="/tag/deburring">deburring</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/airhydraulic-tubing-bender"><img src="/uploads/3612/airhydraulic-tubing-bender.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/airhydraulic-tubing-bender">Air/Hydraulic Tubing Bender</a>
<span> by <a href="/builder/medwards">medwards</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/pocket-knife-sharpener"><img src="/uploads/15288/pocket-knife-sharpener.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/pocket-knife-sharpener">Pocket Knife Sharpener</a>
<span> by <a href="/builder/jvander68">jvander68</a></span>
</div>
<div class="tags">tags: <a href="/tag/grinder">grinder</a>, <a href="/tag/knife">knife</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/air-cylinder-propane-forge"><img src="/uploads/5012/air-cylinder-propane-forge.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/air-cylinder-propane-forge">Air Cylinder Propane Forge</a>
<span> by <a href="/builder/Rob+Garner">Rob Garner</a></span>
</div>
<div class="tags">tags: <a href="/tag/forge">forge</a>, <a href="/tag/propane">propane</a></div>
</div>
</div>
<div class="bimg">
<div>
</div>
</div>
<div class="title">
</div>
</div>
</div>
<div class="bimg">
<div>
</div>
</div>
<div class="title">
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/machete-wrench"><img src="/uploads/15556/machete-wrench.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/machete-wrench">Machete Wrench</a>
<span> by <a href="/builder/EV+Builder">EV Builder</a></span>
</div>
<div class="tags">tags: <a href="/tag/wrench">wrench</a>, <a href="/tag/machete">machete</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/end-mill-sharpener-2"><img src="/uploads/14996/end-mill-sharpener-2.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/end-mill-sharpener-2">End Mill Sharpener</a>
<span> by <a href="/builder/DICKEYBIRD_3">DICKEYBIRD</a></span>
</div>
<div class="tags">tags: <a href="/tag/sharpening">sharpening</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/dust-collector"><img src="/uploads/12017/dust-collector.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/dust-collector">Dust Collector</a>
<span> by <a href="/builder/Dan+Sherman">Dan Sherman</a></span>
</div>
<div class="tags">tags: <a href="/tag/dust-collection">dust collection</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/cyclonic-separator-mod-for-dust-collector"><img src="/uploads/12121/cyclonic-separator-mod-for-dust-collector.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/cyclonic-separator-mod-for-dust-collector">Cyclonic Separator Mod for Dust Collector</a>
<span> by <a href="/builder/JERRY54">JERRY54</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/bandsaw-fence-4"><img src="/uploads/21912/bandsaw-fence-4.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/bandsaw-fence-4">Bandsaw Fence</a>
<span> by <a href="/builder/Jei%27son">Jei'son</a></span>
</div>
<div class="tags">tags: <a href="/tag/bandsaw">bandsaw</a>, <a href="/tag/clamp">clamp</a>, <a href="/tag/fence">fence</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/flat-six-engine-stand"><img src="/uploads/25528/flat-six-engine-stand.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/flat-six-engine-stand">Flat Six Engine Stand</a>
<span> by <a href="/builder/Cupcar">Cupcar</a></span>
</div>
<div class="tags">tags: <a href="/tag/engine">engine</a>, <a href="/tag/stand">stand</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/hardtop-hoist-4"><img src="/uploads/28736/hardtop-hoist-4.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/hardtop-hoist-4">Hardtop Hoist</a>
<span> by <a href="/builder/xxxflhrci">xxxflhrci</a></span>
</div>
<div class="tags">tags: <a href="/tag/hoist">hoist</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/hardtop-gantry"><img src="/uploads/28760/hardtop-gantry.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/hardtop-gantry">Hardtop Gantry</a>
<span> by <a href="/builder/grymsr">grymsr</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/car-rotisserie-4"><img src="/uploads/30948/car-rotisserie-4.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/car-rotisserie-4">Car Rotisserie</a>
<span> by <a href="/builder/HelmetHead">HelmetHead</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/engine-dolly-6"><img src="/uploads/39892/engine-dolly-6.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/engine-dolly-6">Engine Dolly</a>
<span> by <a href="/builder/wildcat85">wildcat85</a></span>
</div>
</div>
</div>
<div class="bimg">
<div>
<a href="/fold-down-workbench-3"><img src="/uploads/47004/fold-down-workbench-3.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/fold-down-workbench-3">Fold-Down Workbench</a>
<span> by <a href="/builder/redryder">redryder</a></span>
</div>
<div class="tags">tags: <a href="/tag/workbench">workbench</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/disc-sander-11"><img src="/uploads/60496/disc-sander-11.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/disc-sander-11">Disc Sander</a>
</div>
<div class="tags">tags: <a href="/tag/disc-sander">disc sander</a>, <a href="/tag/motor">motor</a>, <a href="/tag/switch">switch</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/spot-welder-tips"><img src="/uploads/64516/spot-welder-tips.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/spot-welder-tips">Spot Welder Tips</a>
<span> by <a href="/builder/BradMartinson">BradMartinson</a></span>
</div>
<div class="tags">tags: <a href="/tag/spot-welder">spot welder</a>, <a href="/tag/lathe">lathe</a>, <a href="/tag/tips">tips</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/chamfer-plane"><img src="/uploads/65424/chamfer-plane.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/chamfer-plane">Chamfer Plane</a>
<span> by <a href="/builder/rhoddity">rhoddity</a></span>
</div>
<div class="tags">tags: <a href="/tag/chamfer">chamfer</a>, <a href="/tag/plane">plane</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/truck-crane"><img src="/uploads/82996/truck-crane.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/truck-crane">Truck Crane</a>
<span> by <a href="/builder/coyotencuttin">coyotencuttin</a></span>
</div>
<div class="tags">tags: <a href="/tag/truck">truck</a>, <a href="/tag/crane">crane</a>, <a href="/tag/welding">welding</a>, <a href="/tag/winch">winch</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/generator-10"><img src="/uploads/83060/generator-10.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/generator-10">Generator</a>
<span> by <a href="/builder/Tim_3">Tim</a></span>
</div>
<div class="tags">tags: <a href="/tag/engine">engine</a>, <a href="/tag/generator">generator</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="/trailer-mounted-winch"><img src="/uploads/113638/trailer-mounted-winch.jpeg"/></a>
</div>
</div>
<div class="title">
<a href="/trailer-mounted-winch">Trailer-Mounted Winch</a>
<span> by <a href="/builder/jniolon">jniolon</a></span>
</div>
<div class="tags">tags: <a href="/tag/trailer">trailer</a>, <a href="/tag/winch">winch</a></div>
</div>
</div>
</div>
Some keys to getting value from Harbor Freight:
-Accept that HF will never be the equivalent of a "real" tool supplier.
-Work the sales and discounts and coupons and tricks. An inexpensive tool can turn into a ridiculously inexpensive tool.
-Understand the difference between inexpensive and cheap. Sometimes the difference is important, sometimes it simply doesn't exist.
-Be cautious with consumables. Blades, bits, etc. These need an extra skeptical eye. You don't "save" anything if one breaks at a critical moment, and they will usually break when they are storing the greatest amount of energy.
-You usually get what you pay for. The upside is that this means that you don't get a 50-cent driver for $8, like is sometimes the case at big box stores. That 50-cent driver is usually priced accurately, for better or for worse.
-Get your spelling lessons elsewhere. It takes a special kind of company to stamp a misspelled version of "Pittsburgh" into a tool. :)
-It might be advantageous for you to buy multiple instances of a specific tool, toss them around, lose some, break some, etc. For specific tools, in specific situations, you could come ahead like this, and avoid the stress of monitoring a fancy tool in a certain environment.
-HF might be best as a tool "platform". If you can buy basic tools there, and mod them, you'll likely extract the maximum value from their offerings.
4 Attachment(s)
Harbor Freight Bender mod for on-edge [hardway] forming.
My long running electrical project requires a fair amount of hardware. My installation is somewhat unconventional.
Instead of EMT, IMT or Rigid (heck NO) conduit, opted for wireway. Shop to be is a standalone building, ramped, loading dock high, zoned M1 and entirely free span inside. Profile pic is 9500+ American Pacemaker pounds last 100' from flatbed in California to Midwest doorway. Huge delay awaiting a proper roofer to insure structural integrity above a 110 yr old brick box. Assembling materials continuously, everything is coming together, after god of trusses and 50 yr asphalt shingles sent just such a contractor my way. Delay? Dead set against hanging 3 phase from leaky low pitch roof & rafters. It would negate reasonable corrections later on, or beat me up with constant maintenance $$. Cue up Mark Knopfler and "No Can Do" or "Don't You Get It?". Period.
I work in a steady mode, key elements are function and form in that order. Conducting multiple projects, that obligates me to wring each deeply. Features deemed important are part of plan, not just bolted on. It is the very basis of measure twice /cut once.
So, wireway is being suspended with door flap perpendicular to floor, not on top as usual. Commercial hangers, couplers, tees and ells not ideally designed for that either.
So what? Instead designed complete system to suit the installation. More importantly it presents a clean-looking install that passes a full Electrical Inspection.
A] Drew up hanger and support for max headroom [no pun]. It gets everything plumb and level, directed over each of the machine aisles.
This post is about manufacturing the hanger brace.
I can answer mechanical/ machining questions on the tool modification. Have inserted most everything needed so readers can duplicate or alter as needed. Click the pix, text is embedded already. Apologetically, withholding on the full bracket and other components until install is done, as solution is patentable.
Attachment 10023 Attachment 10024 Attachment 10025 Attachment 10026
My sister holds a Masters in English. According to her, English is comprised of 750,000 words; and someone with a substantial vocabulary uses about 35,000. Much of remaining 700,000 are occupational vocabularies; law, medicine, the sciences, engineering, even religion.
Some are meant to exclude laypersons; from comprehension, practicing or responding. Sort of job security, shelter for those without multiple talents. Television has good examples of introducing terminology, albeit with imperfect definition. Police and law drama, surgical procedures, Arctic fishing, ... I'm disappointed "How It's Made" depicts end products without any of the immense tool-making behind a canning line, custom auto manufacturing, or machine tools themselves. It makes manufacturing appear to be a service, instead of layers of capital investment needed to produce volume. Not to mention economic waves it generates.
I'm prejudiced 'our' vocabulary, that of mechanics, seems most important of all.
Think how it permeates other disciplines. Use those branches to expand your understanding. Look at the geographical span members of this site occupy, the span of interests, abilities, resources, and age. Places like this co-mingle our common language, creativity, and adaptation of other solutions we use as individuals.
1 Attachment(s)
Harbor Freight Bender handle mod.
Getting the bender hardway dies ready, impression of unit was sound, a little loose, but not from scrimping on material, just tolerances.
Handle did not impart the feel desired of operating a tool. Most if not all came from fit of main tube to extension handle, even when retracted. Now it does.
Like my roof mentioned earlier, it won't need more attention later.
Like Rome, brick by brick.
Attachment 10030
Goal is increasingly self-supporting operation, teach a group of intern /students to run it, while I work as leadman /supervisor. A lot like tradeschool, with an entirely different fee program. It is to teach basics, with metal-work at the center. Drafting, hand tools, shop math, welding, sharpening, heat treating etc. Not just because but why, and how they interact.
