Honing Wheel
Here is an extension that can be easily done to the wet grinder :
http://www.labellenote.fr/file/homem...morfiler_0.JPG
http://www.labellenote.fr/file/homem...morfiler_1.JPG
It is a wheel with several profiles of different radii, made out of MDF on the lathe.
The MDF is great for holding honing compound.
This wheel is simply stacked over the existing plastic wheel, which holds a leather rim.
So it is used to hone the flute of carving gouges.
Interestingly polishing the cut ..
:hattip:
Thanks Christophe! I've added your Honing Wheel Extension to our Grinding category, as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="/honing-wheel-extension"><img src="/uploads/103985/honing-wheel-extension.jpeg" alt="Honing Wheel Extension" /></a> </div>
</div>
<div class="title">
<a href="/honing-wheel-extension">Honing Wheel Extension</a> <span> by <a href="/builder/Christophe+Mineau">Christophe Mineau</a></span> </div>
<div class="tags">
tags:
<a href="/tag/wheel">wheel</a>, <a href="/tag/grinding">grinding</a>, <a href="/tag/honing">honing</a>, <a href="/tag/gouge">gouge</a> </div>
</div>
</div>
</div>
I wouldn't have a use for this, but it's a great idea.
