Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Thread: Horizontal Bandsaw "mods"
    May 2012
    Byron, Michigan
    astroracer's Tools
    I have used milling clamps in my H/V for years... Some set-ups are impossible to clamp with the original clamp. The T-nut slips right into the slot for the clamp slider. I have thought about drilling and tapping a few holes for the clamp bolts, just haven't had the need to do so yet. I can usually get most set-ups clamped using the existing slot.
    With the milling clamps I knocked the corners off this stack in less then 10 minutes...
    Mark
  2. The Following 11 Users Say Thank You to astroracer For This Useful Post:
    almarghi (Jul 25, 2018), Andyt (Mar 30, 2018), baja (Aug 27, 2020), dwbachor (Oct 22, 2017), jere (Feb 13, 2015), mwmkravchenko (Nov 13, 2018), Paul Jones (Dec 21, 2014), Sleykin (Mar 29, 2018), Tule (Aug 27, 2020), will52100 (Mar 29, 2018), WinDancerKnives (Jul 25, 2018)
    Jul 2012
    Well, I'll be. I do exactly the same all the time, using the same milling clamp set. I've resisted drilling into the casting as I don't fancy weakening it, and like you I have always managed to get around it. I only use light pressure when clamping up in case the casting breaks.
    One of these days I will add a stop, so the fence can be returned to 90 degrees quickly and easily.
    May 2012
    Byron, Michigan
    astroracer's Tools
    Quote Originally Posted by steve1001 View Post
    Yep, light pressure, just enough to clamp the parts, especially if they can be backed up by the fench.
    I haven't added stops but I did put a heavy scribe mark @ 90, 75, 60 & 45 degrees. Works well for me.
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    Hi Astroracer great post.:O)
    Feb 2013
    South of Brazil.
    Hotz's Tools
    Astroracer..
    great idea, thanks for sharing.
    Sorry my mistakes in english.
    Supporting Member crazypj's Avatar
    Nov 2014
    Central Florida
    crazypj's Tools
    I have a set of milling clamps but hadn't thought of using them on saw. I did fit a 'zero clearance' extension to the outside of vice block so cutting short pieces is safer
  8. #7
    Jul 2014
    crazypj Got a picture of that extension?
  9. #8
    Good tip, astroracer. Something to keep in mind.
  10. #9
    Nov 2014
    Central Florida
    crazypj's Tools
    Here's fuzzy pic of the piece of angle I bolted to bandsaw to support thin material. Still need packing on 'back end' of vice when material doesn't reach to pivot bolt though.
    I butted it against edge of back plate then used saw blade to cut the 'zero clearance' slot.
    Swarf drops through underneath, even the plexiglass I just cut
    Attached Thumbnails Attached Thumbnails Horizontal Bandsaw "mods"-bandsaw.jpg
  11. The Following User Says Thank You to crazypj For This Useful Post:
  12. #10
    Jan 2015
    Eastern North Dakota
    GaryR's Tools
    Hi Guys,
    Had a couple minutes yesterday and decided to get the Jet bandsaw set to cut at 90 degrees as close as I could and drill a 1/4 inch hole through the back jaw and the base. Now I don't have to guess when cutting if I am at 90 or not. I can still pull the pin and move the back jaw.
    GaryR
