Results 1 to 6 of 6
Thread: Hose Reel Mounting Bracket -- Tight Clearance
    Supporting Member bimmer1980's Avatar
    Jan 2018
    bimmer1980's Tools
    Over the last few weeks I've been working on a hose reel bracket to mount a large hose reel at the front center of the garage. The hose reel will site between the two front garage doors and has to clear the door tracks. I recessed the hose reel up in to the truss bay....
    The first step was to shear out some pieces of steel on the Piranha Iron Worker. Luckily I had some steel left over from another project.
    Hose Reel Mounting Bracket -- Tight Clearance-blue-hose-reel-installation-dec-2017-1-.jpg
    Hose Reel Mounting Bracket -- Tight Clearance-blue-hose-reel-installation-dec-2017-2-.jpg
    Then I punched some holes and changed out to the press brake. I bent the two offset flanges.
    Hose Reel Mounting Bracket -- Tight Clearance-blue-hose-reel-installation-dec-2017-3-.jpg
    Time for a check of how it was progressing:
    Hose Reel Mounting Bracket -- Tight Clearance-blue-hose-reel-installation-dec-2017-4-.jpg
    Hose Reel Mounting Bracket -- Tight Clearance-blue-hose-reel-installation-dec-2017-5-.jpg
  2. The Following 2 Users Say Thank You to bimmer1980 For This Useful Post:
    Jon (Jan 10, 2018), Seedtick (Jan 11, 2018)
    Jan 2018
    bimmer1980's Tools
    Next up was some drilling at tapping of holes for mounting the hose reel to the bracket. I didn't get any pictures of that process. Altho here is a video of tapping holes from one of my other projects:
    Then it was on to welding it together. I used my Hobart Beta-Mig that I got on craigslist awhile back. It's a bit of a tank, but it seems to work well for heavy welding... it beats the Century 110 flux core welder....
    Attachment 21396
    Attachment 21397
    After the welding was done, I sandblasted it and then painted it.
    Attachment 21398
    Jan 2018
    bimmer1980's Tools
    Since it was a used hose reel, I did some light cleanup before installation. I also had to thread a hose into it and clamp it appropriately.
    Jan 2018
    bimmer1980's Tools
    Finally it was on to the installation prep...
    I like to use these special lag screws for mounting steel to wood structures.
    Attachment 21399
    Attachment 21400
    Jan 2018
    bimmer1980's Tools
    After some "challenges" I was able to get the hose reel mounted....
    I was able to get the hose reel to hang on one piece of unistrut and then insert the second one on the other side.
    Attachment 21401
    Attachment 21402
    Attachment 21403
    I still need to put the cover on it, then the hose stopper before I can hook up the supply line.
    Thanks bimmer1980! We've added your Hose Reel Bracket to our Storage and Organization category,
    as well as to your builder page: bimmer1980's Homemade Tools. Your receipt:
  8. The Following 2 Users Say Thank You to DIYer For This Useful Post:
    bimmer1980 (Jan 12, 2018), thehomeengineer (Jan 16, 2018)
