Results 1 to 5 of 5
Thread: How to Connect Brushless Washing Machine Motor on 2 speed and Reverse rotation
    Supporting Member HandmadeCreativeChannel's Avatar
    Feb 2019
    Sofia
    HandmadeCreativeChannel's Tools
    Thumbs up How to Connect Brushless Washing Machine Motor on 2 speed and Reverse rotation
    Hello everyone! This is video I want to show you How to Connect Brushless Washing Machine Motor on 2 speed and Reverse rotation . I will show you how to connect wire on 2 speed Rinse /fast/ and Washing /slow/ using а 3 switches ( ON - OFF - ON ) and 4 capacitor.
  2. The Following 3 Users Say Thank You to HandmadeCreativeChannel For This Useful Post:
    H.L (Jul 30, 2020), willy13 (Jul 28, 2020), wolfpaak (Jul 29, 2020)
    Thanks HandmadeCreativeChannel! We've added your Forward and Reverse Wiring for a Motor to our Wiring category,
    as well as to your builder page: HandmadeCreativeChannel's Homemade Tools. Your receipt:
    meyer77's Avatar
    Feb 2019
    meyer77's Tools
    Just a a question. I got a router speed controller for an air compressor I modified to use for a pneumatic hand engraver. On the instructions it says it will not work on brushless motors (the compressor is not brushless).
    What is different in your circuit design?
    Feb 2019
    Sofia
    With a brushless electric motor, we need a starting capacitor. In this situation, "the voltage regulator (Dimmer switch) will not drive the electric motor" Because I do video tutorials on how to wire an electric motor, I did tests with a dimmer switch. the electric motor is running (the speed is not controlled and there is no power).
    While with a brush electric motor this is not a problem.
    jdurand's Tools
    Two types of brushless motors. The induction motors are the original ones, but the name has been pretty much co-opted to mean solid state controlled motors. So, when you see the term you need a bit more info.
