How To Extract Damaged Bolt Or Screw
https://youtu.be/Bsg3lw5CrkA
This video demonstrates the extraction / removal of the damaged head bolts or screws, using the damaged bolt extraction bits.
Damaged Bolts & Screws Removal Kit:
https://amzn.to/3aocb4l
DeWalt Cordless 20V Brushless XR Trim Router:
https://amzn.to/3mD2DIu
DeWalt Trim Router Round Sub Base Replacement:
https://amzn.to/3Bx0eFA
There are quite a few damaged bolt remover kits, and I tried nearly all of them. I believe this HSS hardened steel works very well, as shown in this video.
Once you remove the broken bolts or screws, it is advisable to replace them with the stainless steel, heavy duty equivalent, so that you wouldn't run into the same problem in the future.
