Results 1 to 6 of 6
Thread: How to lift pavers without damaging them
    olefella's Avatar
    olefella's Tools
    One of the most difficult things about a paved surface is lifting the pavers out of the surface without damaging them. In many cases it is impossible, and various techniques such as using a screwdriver, prybar, hammer etc end up either breaking the edges or damaging the paver. In the end it is often easier to break up a paver and pull out the pieces.
    Here is an idea for non-destructive lifting method using old spring steel plaster spatulas or an old backsaw. The lifting plates are easy to make and cost nothing.
    I show how to make the plates and demonstrate by lifting some of the pavers around the yard - in one spot the cars are usually parked and the pavers haven't been disturbed for about 30 years.
  2. The Following 16 Users Say Thank You to olefella For This Useful Post:
    Andyt (May 5, 2020), candsgrandmaster (May 12, 2020), DIYer (May 2, 2020), Duke_of_URL (May 10, 2020), emu roo (Apr 15, 2026), FEM2008 (May 4, 2020), garage nut (May 2, 2020), johncg (Jan 19, 2023), Jon (May 7, 2020), llh49 (May 5, 2020), mwmkravchenko (May 11, 2020), natie123 (May 5, 2020), Quinton 357 (May 4, 2020), Ralphxyz (Jan 9, 2024), sossol (May 5, 2020), Toolmaker51 (May 10, 2020)
    Thanks olefella! We've added your Paving Tile Lifting Method to our Miscellaneous category,
    as well as to your builder page: olefella's Homemade Tools. Your receipt:
    Sep 2013
    Karl_H's Tools
    Thanks.
    I especially like that you show where you are headed before you start.
    So many videos jump right in, so they are 5 minutes in before you can tell what they are making.
    Any tricks to drilling the holes in the spring steel? It seems that would be hard to do.
  5. The Following User Says Thank You to Karl_H For This Useful Post:
    olefella's Avatar
    olefella's Tools
    Quote Originally Posted by Karl_H View Post
    Thanks.
    The better the spring steel the harder it is. I used tap fluid and a high quality drill bit, blunted a few cheap ones en route.
  7. The Following 2 Users Say Thank You to olefella For This Useful Post:
    emu roo (Apr 15, 2026), Karl_H (May 10, 2020)
    Mar 2018
    Hoosiersmoker's Tools
    Thanks.
    I have used a slightly modified masonry bit with success when drilling spring steel.
    "The man who views the world at 50 the same as he did at 20 has wasted 30 years of his life."
    - Muhammad Ali
  9. The Following 2 Users Say Thank You to Hoosiersmoker For This Useful Post:
    emu roo (Apr 15, 2026), Karl_H (Jan 10, 2024)
  10. #6
    olefella's Avatar
    olefella's Tools
    Quote Originally Posted by olefella View Post
    And I've used cobalt steel bits successfully, but they're expensive.
  11. The Following 2 Users Say Thank You to olefella For This Useful Post:
