Results 1 to 10 of 10
Thread: How to make a Hose Clamp wire binding Tool - video
    Supporting Member diyfixman's Avatar
    Jan 2019
    diyfixman's Tools
  2. The Following 22 Users Say Thank You to diyfixman For This Useful Post:
    albertq (Dec 22, 2023), Andyt (Mar 4, 2021), baja (Feb 7, 2019), David Johnson (Feb 7, 2019), David Schwartz (Feb 6, 2019), Gregraper33712 (Feb 7, 2019), JoeVanGeaux (Feb 7, 2019), johncg (Mar 4, 2021), Jon (Feb 6, 2019), PJs (Feb 7, 2019), Ralphxyz (Jan 17, 2024), rgsparber (Feb 6, 2019), rlm98253 (Feb 6, 2019), Scotsman Hosie (Feb 7, 2019), Scotty1 (Feb 6, 2019), Seedtick (Feb 6, 2019), sossol (Oct 6, 2022), Sprig1 (Feb 7, 2019), Tonyg (Feb 7, 2019), volodar (Feb 6, 2019), will52100 (Feb 6, 2019), wolfpaak (Feb 7, 2019)
    Oct 2017
    i hope that was not brass or copper wire i saw u using,, it would be too soft and loosen,,steel wire only..
    Supporting Member will52100's Avatar
    Oct 2015
    Bassfield, MS
    will52100's Tools
    Looks like rusty tie wire to me.
    courtneyknives.net
  5. The Following User Says Thank You to will52100 For This Useful Post:
    PJs (Feb 7, 2019)
    Jan 2019
    diyfixman's Tools
    I did not find a normal thread so I used the thread I found just for the video and chill out everything fine friends
  7. The Following User Says Thank You to diyfixman For This Useful Post:
    blkadder (Feb 10, 2019)
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Well done DIYfixman. Nice video and robust tool for use!
    Mark Twain
  9. The Following User Says Thank You to PJs For This Useful Post:
    diyfixman (Feb 7, 2019)
  10. #6
    peter_351's Tools
    Nice work diyfixman , I did one a while ago, heres what I did , next one I make I will weld a 3/8 or 1/2_drive socket on the end of spinning split pin.
    Attached Thumbnails Attached Thumbnails How to make a Hose Clamp wire binding Tool - video-wire_hose_clamp1.jpg
  11. The Following 4 Users Say Thank You to peter_351 For This Useful Post:
    diyfixman (Feb 8, 2019), Jon (Feb 7, 2019), PJs (Feb 8, 2019), sossol (Oct 6, 2022)
  12. #7
    Thanks diyfixman! We've added your Clamp Wire Binding Tool to our Fastening category,
    as well as to your builder page: diyfixman's Homemade Tools. Your receipt:
  13. The Following User Says Thank You to DIYer For This Useful Post:
    diyfixman (Feb 13, 2019)
  14. #8
    Thanks peter_351! We've added your Wire Clamp Tool to our Fastening category,
    as well as to your builder page: peter_351's Homemade Tools. Your receipt:
  15. #9
    Sep 2018
    Looking at all the tools and ways to do this, I'm bothered about the waste of so much wire. A few here and there , not an issue. But more and more it just becomes pure waste. I have many times wrapped wire around a few times and then just twist the wire together till its snug. Never had a leak or failure with very little wire used.
  16. #10
    hemmjo's Tools
    I made one like this several years ago. The wasted wire does "hurt" my sensitivity to waste. However that is sometimes over powered by the desire to have a clean, tight, secure, nice looking clamp. Due to the wasted wire, about the only place I use it replace ends on air or water hoses. You do have to make sure you get those sharp ends tucked in really well!!!
    I do save the "wasted" wire ends. I tell myself that someday I will get a TIG welder. They will make good filler for stainless steel projects.
    Or they can be used as you mentioned by just wrapping with a twist to secure it.
    Download plans for clamps.
