Results 1 to 6 of 6
Thread: How to make a Hydraulic Jack works UPSIDE DOWN
    Supporting Member Mr.DK DIY's Avatar
    Jan 2019
    Mr.DK DIY's Tools
    Hello,Today my NEW Homemade video project
    UPSIDE DOWN ! / How to make a Hydraulic Jack works UPSIDE DOWN
  2. The Following 9 Users Say Thank You to Mr.DK DIY For This Useful Post:
    Chlor (Oct 9, 2020), emu roo (Jun 12, 2025), j.bickley (Oct 11, 2020), pauladan@magtech.ca (Oct 7, 2020), Sprig1 (Oct 11, 2020), Tooler2 (Oct 16, 2020), trigger (Oct 7, 2020), Tule (Oct 8, 2020), universal scale models (Oct 12, 2020)
    Supporting Member Ram50V8's Avatar
    Mar 2019
    Over the years I have found my self in a position where I really needed a jack I could run upside down. I have numerous times thought about doing something like this but never pursued it. Thank you for the wonderful demonstration, I will definitely remember it the next time I need a jack capable!!
  4. The Following User Says Thank You to Ram50V8 For This Useful Post:
    Mr.DK DIY (Oct 9, 2020)
    mlochala's Avatar
    Nov 2012
    mlochala's Tools
    Thank you for sharing this. I have a few questions, though:
    1) I noticed when you put the zip ties on to secure the hose, it appeared the hose (pickup tube) was nearly flattened. How is that picking up enough fluid?
    2) What kind of glue was that?
    3) If the new pickup tube goes all the way to the top of the reservoir now, how does it still work in right side up position?
  6. The Following User Says Thank You to mlochala For This Useful Post:
    Mr.DK DIY (Oct 22, 2020)
    olderdan's Tools
    You could look at Tony Foals first post on HMT which is a very clear and thorough explanation on inverting a hydraulic jack.
    Inverting an hydraulic jack for a workshop press.
  8. The Following 2 Users Say Thank You to olderdan For This Useful Post:
    Jon (Oct 12, 2020), Mr.DK DIY (Oct 22, 2020)
    Jyväskylä Finland
    Tuomas's Tools
    I posted this about two weeks ago.
    I think.. instead of using glue. This works better / is more reliable way.
    Diy hydraulic puller / pusher
  10. The Following User Says Thank You to Tuomas For This Useful Post:
  11. #6
    Supporting Member Hans Pearson's Avatar
    Jan 2017
    I used much the same method some time ago, but I used an aluminium tube with a thread cut into it and threaded the pick-up hole to match. I remember hitting a snag where the reservoir sucked in air and built up pressure which blew out the rubber stopper. I solved that by putting a filter breather in place of the stopper. Since then I converted to an external pump which overcomes the problem of pumping upwards on my press.
