Results 1 to 8 of 8
Thread: How to make a Simple and Powerful Voltage regulator using MosFet Transistor and NE555
    Supporting Member ercaneverything's Avatar
    Nov 2022
    Bulgaria
    ercaneverything's Tools
    How to make a Simple and Powerful Voltage regulator using MosFet Transistor and NE555-videocapture_20230222-133732-02.jpegHow to make a Simple and Powerful Voltage regulator using MosFet Transistor and NE555-videocapture_20230222-133653-01.jpeg
    Attached Images Attached Images
  2. #2
    Aug 2012
    Australia
    desbromilow's Tools
    looks like the 555 is running as a Pulse width modulator and using the MOSFET for current capacity. This is a nice tidy package for space constrained control boards - my taig lathe uses a commercial version of this circuit (24VDC electric scooter speed controller) and due to the MOSFETs in that it can handle 300W but is considerably bigger and needs some form of cooling to survive.
    these circuits are great to have, and I'm hoping to get good enough at electronics to build a similar one for 380VDC input - I think there i have to use triacs though instead of MOSFETs.
    The schematic is shown in the video, but I took a snapshot and is shown below:
    How to make a Simple and Powerful Voltage regulator using MosFet Transistor and NE555-pwm_v_regulator.png
  3. The Following User Says Thank You to desbromilow For This Useful Post:
    ercaneverything (Feb 24, 2023)
    Sep 2018
    nova_robotics's Tools
    What's with the weird red and blue coils of wire that don't connect to anything?
  5. The Following User Says Thank You to nova_robotics For This Useful Post:
    May 2016
    Don42's Tools
    You can use MOSFETs at 380 volts, no problem, just depends on how much current you need.
    Vishay SIHA6N80AE-GE3 is a 600-volt 5-Amp part for $1.21 at Digi-Key.
  7. The Following User Says Thank You to Don42 For This Useful Post:
    desbromilow (Feb 22, 2023)
    Thanks ercaneverything! We've added your Voltage Regulator to our Electronics category,
    as well as to your builder page: ercaneverything's Homemade Tools. Your receipt:
  9. The Following User Says Thank You to DIYer For This Useful Post:
  10. #6
    Supporting Member h7eh7e's Avatar
    Jun 2017
    Ukraine. Krivoy Rog.
    h7eh7e's Tools
    perhaps this will help you.
    How to make a Simple and Powerful Voltage regulator using MosFet Transistor and NE555-dc-220v-20a-.jpg
  11. The Following User Says Thank You to h7eh7e For This Useful Post:
    desbromilow (Feb 28, 2023)
  12. #7
    Nov 2022
    Bulgaria
    You can use an high voltage mosfet but you need to supply IC555 with fixed voltage up to 18V.
  13. #8
    Nov 2022
    Bulgaria
    These spiral wires are to get attention, and they have no duties.
