Thread: How To Remove A Broken Center Drill
    Supporting Member shopandmath's Avatar
    Jun 2019
    Kitchener ON,CA,
    shopandmath's Tools
    At the end of this video is a short bit on what to look for in a center drill
    The cheep junk (split grind) center drills are not worth what you spent on them
    I am having to remove broken tip about 2 to 5 each class
    The number of people trying to drill out a HSS center drill with a HSS center drill is just upsetting
    Ray
    Video URL
  2. The Following 9 Users Say Thank You to shopandmath For This Useful Post:
    Alan Purdy (Jul 19, 2019), Andyt (Jul 19, 2019), baja (Jul 22, 2019), Crusty (Jul 23, 2019), Jon (Jul 25, 2019), mwmkravchenko (Jul 18, 2019), Paul Alciatore (Jul 23, 2019), Saltfever (Jul 19, 2019), sossol (Jul 18, 2019)
    Supporting Member high-side's Avatar
    Jun 2018
    How's the end of that 3 flute carbide end mill looking after machining HSS?
    Pat
  4. The Following User Says Thank You to high-side For This Useful Post:
    shopandmath (Jul 23, 2019)
    Jun 2019
    Kitchener ON,CA,
    shopandmath's Tools
    The choice of the three flute end mill was one of convenience
    I have a half dozen of them in my toolbox and we can’t use them for anything because the tapered
    There was no chips or anything I noticed that the time wrong with the end mill
    I’m on vacation for the next little bit when I go back I’ll trying take a picture of it
    Ray
    Mar 2014
    Beaumont, TX
    Paul Alciatore's Tools
    On the tip at the end on better center drills, can you explain why the spiral cut one is stronger? The one on the left that you refer to as a straight cut is what I have seen and most, if not all of my center drills are that style. But the one you show looks like it has a very poor finish, possible already cracked. None of mine are like that. They have nice, ground finishes like most of my drill bits and end mills do. Is that the reason why the one on the left is no good? Or what? I would think that they both have about the same amount of cross sectional area at the base of the small diameter area, which is where center drills normally break.
    AND, just where do you get those spiral cut ones? What brand? What are they called, other than center drills?
    Paul A.
  7. The Following User Says Thank You to Paul Alciatore For This Useful Post:
    shopandmath (Jul 24, 2019)
    Jun 2019
    Kitchener ON,CA,
    shopandmath's Tools
    Hi Paul
    Thank you for your email
    I’m going to try and answer each question in point form
    first question
    can you explain why a spiral cut is stronger
    The spiral cut has a Web just like a drill it starts off small at the top and tapers down wider as you go into the centre Drill Like a skinny pyramid almost or triangle The straight cut doesn’t taper
    Second question
    Most center drills are straight cut
    When I complained about straight cut It was explained to me the cost is almost 10 to 1
    That is why the quality of the grind on the Straight cut in the photo is so low
    The only time we get the spiral cut centre drills is when they are solid carbide
    Question three
    Do they have the same amount of cross-section
    This is where the problem lies if they have equal cross-section the spiral flute will be stronger
    Scenario. Have you ever picked up a Centre drill looked or measured the Cross section?
    If you’re machining an expensive part would you use a no-name tap or a high-end tap
    The only time you’re going to look at the cross-section thickness is if the Centre drill breaks then it’s too late
    If you’ve never broken Centre drill keep using them they are just fine
    Question four
    Where do you get the spiral cut
    I have rarely ever bought centre drills I’ve told other people to get them for me and they just show up When I have ordered Centre drills I purchased them from Sowa tool and machine Co.
    In Kitchener Ontario
    I have also purchased them from Sowa in Calgary for the 2009 world skills competition
    If I have missed any other questions or have not quite explained everything or if you have any other questions Please let me know
    I went to my toolbox at home and got all of my center drills
    And was surprised there are no straight cuts
    Added photo
    Ray
    Jun 2018
    If your using center drills to spot holes for general drilling & tapping, why bother searching for the strongest center drill when you should just use a proper spot drill instead. No small tips to break off, and more accurate spotting.
    Pat
  10. The Following 2 Users Say Thank You to high-side For This Useful Post:
    olderdan (Jul 24, 2019), shopandmath (Jul 24, 2019)
  11. #7
    Jun 2019
    Kitchener ON,CA,
    shopandmath's Tools
    Thank high-side you for your response
    You are correct (what can I say) right is right
    In the circumstance my students are in the toolbox they buy only have center drills in it
    The CNC have spot drills
    Spot drills work best with rigid equipment/setups center drill are a little more forgiving
    Ray
  12. The Following 2 Users Say Thank You to shopandmath For This Useful Post:
    olderdan (Jul 24, 2019), Toolmaker51 (Sep 1, 2021)
