Results 1 to 10 of 15
Thread: How To Use Inductive Proximity Sensors
    Supporting Member GBWM's Avatar
    Nov 2021
    GBWM's Tools
    A short video showing how to wire up inductive proximity sensors in our homemade machines. These sensors are used to detect metal. Proximity sensors are useful for example as limit switches in CNC controlled machines like CNC routers, mills, or lathes but the use of them is really wide.
  2. The Following 7 Users Say Thank You to GBWM For This Useful Post:
    carloski (Apr 25, 2022), durrelltn (May 1, 2022), emu roo (May 22, 2026), NortonDommi (Apr 30, 2022), nova_robotics (Apr 25, 2022), rarmintrout (Apr 26, 2022), Saltfever (Apr 29, 2022)
    I use those sensors on my lathe conversion.
    Here is a photo showing the X-axis sensor in place
    How To Use Inductive Proximity Sensors-ballscrew_113.jpg Click for full size.
    Here is the setup with the trigger bar in place, the gold coloured piece.
    For both X and Z axis I use one sensor on each axis with two triggers. Sometimes two sensors are used with one trigger. It depends what you want to do with the information. In my case I just wanted limit switches.
  4. The Following 3 Users Say Thank You to tonyfoale For This Useful Post:
    emu roo (May 22, 2026), nova_robotics (May 1, 2022), Saltfever (Apr 29, 2022)
    Thanks GBWM! We've added your Proximity Sensor Wiring to our Wiring category,
    as well as to your builder page: GBWM's Homemade Tools. Your receipt:
    Thanks tonyfoale! We've added your XZ Limit Switch Setup to our Lathe Accessories category,
    Nov 2021
    GBWM's Tools
    Do you use them as home switches too? I'm wondering how accurate are these actually as I'm thinking of using them in my next machine as home switches.
  10. The Following User Says Thank You to GBWM For This Useful Post:
  11. #6
    Quote Originally Posted by GBWM View Post
    I do not have nor need homing switches on this lathe. So the answer is NO. See Ball screw and electronic lathe conversion
    If I were to need homing switches on which to base repeatable positioning I do not think that I would trust these proximity sensors to provide the required accuracy. For homing I would choose optical sensors, I used the proximity sensors mainly because I had a few left over from a project of nearly 40 years ago. They do have the bonus of being fairly rugged and tolerant of cooling fluids etc. Optical sensors need protection from the fluids. Hall effect sensors offer better protection but I would not trust their precision as much as optical like these, which are cheap as chips.
  12. The Following 2 Users Say Thank You to tonyfoale For This Useful Post:
    emu roo (May 22, 2026), GBWM (Apr 27, 2022)
  13. #7
    Apr 2016
    Centurion, South Africa
    I use them as homing switches on some of the large CNC plasma machines that I manufacture and they are extremely accurate. (bearing in mind that you get a wide range of proximity switches which vary in quality and of course price)
  14. The Following User Says Thank You to Tonyg For This Useful Post:
    metalsmith1952 (Apr 27, 2022)
  15. #8
    Supporting Member Guy Marsden's Avatar
    Mar 2022
    Maine USA
    Guy Marsden's Tools
    There are also magnetic sensors that look almost identical and they will detect either a N or S pole from a short distance just like these inductive sensors. They come stock with the inexpensive tachometers that I've installed on all my equipment:
  16. The Following 8 Users Say Thank You to Guy Marsden For This Useful Post:
    asterix (Apr 27, 2022), emu roo (May 22, 2026), Floradawg (May 1, 2022), metalsmith1952 (Apr 27, 2022), NortonDommi (May 2, 2022), nova_robotics (Apr 27, 2022), rarmintrout (Apr 28, 2022), Saltfever (Apr 30, 2022)
  17. #9
    Quote Originally Posted by Tonyg View Post
    Can you put some measured numbers to "extremely accurate"?
  18. #10
  19. The Following User Says Thank You to tonyfoale For This Useful Post:
