Thread: Hyd. cyl gland nut
    Hyd. cyl gland nut
    The gland nut on 1 of the Siamese cylinders had some weak looking threads once I had it removed. I decided I should make a new one rather than try and clean up the threads on the old nut.
    I started out with a roller I had left over from a bygone era of manufacturing 2 post lifts
    I faced off 1 side
    then bored to size deep enough to make the nut
    Then added the wiper grove
    Then turned the OD and treaded to 12TPI and used a stone to smooth the threads
    Its hard to see but I scribed a mark on the OD incase I needed to return the nut to the lathe and take off a little more of the thread depth
    Once satisfied the nut would mate up to the threads in the cylinder I chucked it from the opposite side and removed the excess thickness
    the finished nut
    Assembly
    Carving a piece of wood makes the best drift for tapping the gland in place. My brass and aluminum drifts were too large in diameter.
    I will put this in my tool box to use again
    Fully assembled
    baja (Jun 16, 2022)
    Thanks Frank S! We've added your Hydraulic Cylinder Gland Nut to our Miscellaneous category,
    Supporting Member baja's Avatar
    Dec 2017
    baja's Tools
    Thanks for the luck on my forklift project, Frank. I heated the end of the pin for a couple three minutes with a small welding tip and whacked the pin and it started moving. Sitting on the bench right now waiting for me to pull it apart.
  5. The Following User Says Thank You to baja For This Useful Post:
    Frank S (Jun 16, 2022)
    piper184's Avatar
    Jul 2016
    piper184's Tools
    Nice work Frank. Always amazing what you can do with some scrap and the proper tools.
    The tendency to save "everything" pays even larger dividends now that I have a lathe. I now understand how a sculptor can look at a rock and "see" the art inside. Now I see parts inside of other parts. The trick is getting them to come out.
    Now if I can just find a mill....
    Quote Originally Posted by piper184 View Post
    The worst thing about getting a mill is you will start to invent things you would never have thought of. I'm starting to think of a scraper and a surface grinder
