Thread: Hydraulic diverter valve mounting plate.
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    After fitting the thumb grab to my mini digger there was no option to add additional hydraulic attachments to the auxiliary lines. I have decided to build a tilting grading beam so will need to link the hydraulics to the beam’s cylinder. To achieve this a couple of diverter valves are need to be fitted in place of the isolation valves currently fitted to create additional lines.
    To fit the diverter valves a mounting plate was needed to clamp the valves to the digger.
    New hydraulic fittings were also purchased.
    The photos below show the valves and mounting plates.
ID:	48322Click image for larger version.
ID:	48323Current set up with isolation valve either side.
ID:	48324New mounting brackets.
ID:	48325 Click image for larger version.
ID:	48326 Click image for larger version.
ID:	48327Diverter valve mounted to plate and digger.
ID:	48328Both valves are fitted directly to the thumb grab and the other output of the valves is fitted with a quick release couplings. This creates the additional auxiliary output lines, so the thumb can be isolated and the tilting beam fitted without the need to disconnect the thumb’s plumbing.
    Thank you for viewing
    The Home Engineer
  2. The Following 3 Users Say Thank You to thehomeengineer For This Useful Post:
    Jon (Dec 1, 2024), metric_taper (Nov 19, 2024), Philip Davies (Nov 25, 2024)
