Thread: Hydraulic hand pump - video
    Hydraulic hand pump. By Make it Extreme. 17:48 video:
  2. The Following User Says Thank You to Jon For This Useful Post:
    uv8452 (Jun 13, 2022)
    Oct 2019
    Germany
    uv8452's Tools
    Very nice endeavour. Everyone will find a small custom-made hydraulic system very practical. I miss (missed I?) a schematic; and a short calculation of hand force, max. pressure und throughput. I fear for the plunger tilting - I don't know the guiding properties (length) of the thing with the blue wiper.
    I can see that would be useful, provided you have all of the accessories. I do see an error in the plumbing. The fitting string between two fixed points in a system needs to have a bit of adjustment to allow for tightening the various components. The top plate has been bent by the fittings. Using a bulkhead fitting in an elongated hole would provide acceptable adjustment in this situation.
    The schematic is pretty straight forward.
  5. The Following User Says Thank You to hemmjo For This Useful Post:
    uv8452 (Jun 15, 2022)
    Oct 2019
    Germany
    uv8452's Tools
    Dear hemmjo, thank you for the explanation indeed. A dirty but effective trick to make a connection 'longer' is to put an additional gasket, copper ring or the like. Or file the bolt-through bores for the main pumping block to ovals. Put washers and no-one will notice.
