Results 1 to 9 of 9
Thread: I turn Car Compressor into Working Engine
Hybrid View
    Supporting Member Let'sLearnSomething's Avatar
    Nov 2018
    Let'sLearnSomething's Tools
    Lightbulb I turn Car Compressor into Working Engine
    Let's Learn Something: Project no.22
    Good day guys
    I know you are wondering that why i turn this Car compressor into engine is because I want to explore my knowledge into something different that i never tried before.
  2. The Following 12 Users Say Thank You to Let'sLearnSomething For This Useful Post:
    baja (Nov 27, 2019), Eaglewood (Nov 26, 2019), emu roo (Nov 15, 2025), jimfols (Nov 26, 2019), Jon (Nov 26, 2019), Marine2171 (Nov 26, 2019), MIGuy (Nov 26, 2019), mr herb (Nov 27, 2019), Quinton 357 (Nov 26, 2019), sossol (Nov 26, 2019), will52100 (Nov 27, 2019), wolle (Nov 28, 2019)
    Interesting experimental build
    Supporting Member Eaglewood's Avatar
    Mar 2016
    Eaglewood's Tools
    Who da thought. Way outside the box��
  6. The Following User Says Thank You to Eaglewood For This Useful Post:
    Oct 2012
    Lafayette, Indiana
    sossol's Tools
    Very cool build. It's like the Duke engine (and torpedo engines before it), except 1/1000th the cost. I'm curious about how well the PTFE coating on the pistons held up.
    Neil
    Supporting Member Hans Pearson's Avatar
    Jan 2017
    Brilliant idea and ingenious construction. Obviously the head won't hold for long but let us know about the pistons/
  9. The Following User Says Thank You to Hans Pearson For This Useful Post:
  10. #6
    This project gets the mental juices flowing.
  11. The Following User Says Thank You to owen moore For This Useful Post:
  12. #7
    Makes me wish I did not have some many other projects in the fire. How do you get enough free time to explore things like that!!!!
  13. The Following User Says Thank You to hemmjo For This Useful Post:
  14. #8
    Nov 2019
    That is pretty cool. I would assume more friction with a swashplate than just perpendicular bearings on a crankshaft, but that's how helicopter blades are adjusted. If designed from the ground up, would make a pretty compact engine. BUT, dude, please buy at least a cheap drill press vise!
  15. #9
    Quote Originally Posted by rdarrylb View Post
    That is pretty cool. I would assume more friction with a swashplate than just perpendicular bearings on a crankshaft,....snip.!
    Hydro Static drives also use swash plates for both the pump and motor.
