Quote Originally Posted by acourtjester View Post
Here are pictures of a Powder coating oven I built. I used 2 50 gal drums (shortened) to make the oven inside. For the elements I used 2 stove top burners (22300 watt) a PID (temp controller). A SSR to switch the power on to the burners. You turn it on and set the temp on the PID and its ready to go after it heats up. The PID keeps the temp at what you set it. I lay it down to use one picture shows a trolley for hanging parts and moving into the oven. That is a bead roller frame I built and powder coated in the oven. I roll it around like a wheel barrow and stand it up on its end for storage.
Have fun
Tom
Can you provide some more details, insulation, pid, door seals, etc?
Bake times?
