Quote Originally Posted by mansworld View Post
Carbide saw blades are no different than lathe carbide insert cut off/ parting tools. No matter how careful you are, saw blades and cut off tolls with carbide attachments will break from even the slightest shocks till you reach the point to say: Enough is enough, and go back to abrasive cut off discs, and find alternative methods to cut off/part on the lathe.
You should try using abrasive disks to cut aluminum sometime, then you will go back to using carbide blades
