Results 1 to 7 of 7
Thread: Industrial press brake bending thick steel - GIF
  2. The Following 4 Users Say Thank You to Altair For This Useful Post:
    mwmkravchenko (Jul 19, 2023), nova_robotics (Jul 19, 2023), piper184 (Jul 20, 2023), Ralphxyz (Jul 22, 2023)
    hemmjo's Tools
    Impressive, how do that close up that final gap for welding?
    Perth Ontario Canada
    An expensive way to make pipe!
    Mark
    Lake Tahoe
    IntheGroove's Tools
    It could possibly make a fairly good submersible...
    Quote Originally Posted by mwmkravchenko View Post
    Mark
    Not really, considering how much it would cost to lay in a complete pipe making production line for a pipe of that size and thickness which could be in the of millions of dollars, just for a pipe making line capable of producing pipe nowhere near as thick as that one.
    Obviously still not cheap for a press break that large plus a clamping machine to close the final gap a submerged arc welding system that would be mounted on a long pole to be sent to weld the inside and then the outside of the seam, but you would still have be able to weld the seam on a pipe production line, the exception being a seamless pipe forging line.
    It all boils down to nothing is cheap when dealing with big and or thick materials.
    hemmjo's Tools
    Quote Originally Posted by IntheGroove View Post
    Actually this is not nearly strong enough for 15,000 feet. 15,000 Ft ÷ 33ft/atm ≈ 455 atmospheres x 14 psi ≈ 6000+ psi.
    Click to enlarge.
    2500 is a lot less than 6000!!!!!!
  8. The Following User Says Thank You to hemmjo For This Useful Post:
    ductape (Jul 19, 2023)
  9. #7
    Dec 2022
    Midwest US
    ductape's Tools
    Click to enlarge.
Name:	Pipe Pressure.png
    If this is 4"/100mm thick with perfect welds and appropriate ends put on, it would be crushed at about 5700 feet/1750m according to this. That amount of pressure is very hard to imagine. Wow.
