Results 1 to 10 of 10
Thread: Installing a connecting rod bearing using liquid nitrogen - GIF
Hybrid View
    nova_robotics (Oct 10, 2023), Ralphxyz (Oct 14, 2023)
    Why wouldn't you add a stop plate under the journal of the connecting rod. to hold the bearing in the exact place you wanted it instead of relying on the insulating quality of your gloves to keep your fingers from freezing while the bearing warmed and seized into the rod?
    Ralphxyz (Oct 14, 2023), rdarrylb (Oct 12, 2023)
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    Because stop plates are more expensive than fingers...
    sad but true
  6. The Following 2 Users Say Thank You to BuffaloJohn For This Useful Post:
    Frank S (Oct 10, 2023), rdarrylb (Oct 12, 2023)
    Supporting Member bob_3000's Avatar
    Aug 2020
    Quote Originally Posted by BuffaloJohn View Post
    or because the gloves work he has his fingers and all is well
  8. The Following User Says Thank You to bob_3000 For This Useful Post:
    Quote Originally Posted by bob_3000 View Post
    Yes, gloves work, and it only takes a few seconds for the bearings to warm enough to seize, you've got 1 chance to get it right and no chances to correct it, during those few seconds the bearing should be held in the correct position relative to the rod journal Maybe since there is side to side play inside the piston it is not that critical. I like things properly centered and by touch through a thick glove doesn't always work. If he gets distracted by say a mosquito or noise or anything, he could allow the bearing to slip before it seizes.
  10. #6
    Howder1951's Avatar
    Jan 2016
    Yes, all it takes is a clamp and a piece of scrap and 10 seconds. All you have to do is measure to be sure and have a back up hammer if it sticks on anything, unless one has had the joy of the bearing bouncing and seizing on the up travel.
  11. The Following User Says Thank You to Howder1951 For This Useful Post:
    Frank S (Oct 12, 2023)
  12. #7
    May 2015
    Tasmania, Australia
    Bony's Tools
    And he's not wearing a face shield or even safety glasses!
  13. #8
    Feb 2018
    One question that I have is : one can see 2 holes in the bearing and rod, presumably for lubrication. I don't see if he aligned them by eye or what ??
  14. #9
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    Quote Originally Posted by unmore View Post
    There appear to be two grooves in the rod end as well, which match grooves we can see in the bearing. The fellow is aligning the bearing with the two circular holes facing the rod.
    I would imagine there must be some sort of opening in the rod end which lets oil enter the circular openings which then lets oil make its way to the grooves. Since the rod end is one piece and closed, there must be a pin that goes through the bearing, so it would be logical to assume there is some sort of external oil source that needs the holes and grooves.
  15. #10
    I need 2 of those rods for my next V twin build I'm thinking maybe a 61 liter build should do it
