Results 1 to 5 of 5
Thread: Installing skirting boards beside a stepped floor - GIF
    May 2024
    Installing skirting boards beside a stepped floor.
    Corner skirting molding - GIF
    Skirting board ending finishing technique - GIF
    Skirting board installation around an obstacle - GIF
    PJs (Aug 21, 2025)
    This one makes more sense than the one around the pipe
  4. The Following 4 Users Say Thank You to Frank S For This Useful Post:
    baja (Aug 24, 2025), BuffaloJohn (Aug 19, 2025), Duke_of_URL (Aug 20, 2025), PJs (Aug 21, 2025)
    Dec 2018
    Well done - not sure how long it would have taken me to figure it out. Thank you.
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    This was pretty clever and looked great. Back when I was teaching Drafting and CAD I required students to board draft first so they would learn about constructing layout lines for complex shapes in projects...basically Geometry. This gave them the wherewithal to see how to construct pretty much anything. The final was a 6 bladed fan with a complex center-mount and curved blades with tangential curves and the working drawing they used had minimal dimensions. Once they could see how the geometry worked CAD became easy because you draw a few lines and mostly edit to get the desired shapes.
    I Agree with Frank about the pipe....butt them together and bore the hole in both. It would have looked better and it looks like the hole would come out just below the bevel.
    Mark Twain
    Mar 2018
    Hoosiersmoker's Tools
    Make sure to do it BEFORE you paint the wall...
    "The man who views the world at 50 the same as he did at 20 has wasted 30 years of his life."
    - Muhammad Ali
