https://youtu.be/gvx2EN4xP4M
Thanks Improvised DIY! We've added your Keyway Cutter to our Metalworking category,
as well as to your builder page: Improvised DIY's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-keyway-cutter-11"> <img src="/uploads/261016/homemade-keyway-cutter-11.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-keyway-cutter-11">Keyway Cutter</a> <span> by <a href="https://www.homemadetools.net/builder/Improvised+DIY">Improvised DIY</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/cutter'>cutter</a> </div> </div> </div> </div>
The tool-post appears somewhat lacking in rigidity...
The entire compound was moving here. There is a lot of force involved with the width of cut on this small machine.
@ 20.18 one can see the slotting tool frame moving in relation to the compound...
